Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Is my clutch shot?
Old Aug 14, 2009 | 02:12 PM
85_305's Avatar
Default Is my clutch shot?
Go to start my car after work, as the car is cranking it is also trying lurch forward. Reverse grinds trying to go in. The car goes thru the gears whil car is off just fine. Fluid levels are fine. Clutch has same firmness as I recall it ever having.
When I'm driving I can trucker-shift it w/out using the clutch.
There were ZERO warning signs of it failing. It drove to work fine, but didn't make it out of work fine.
Just as an FYI, it was flooding at work earlier and I drove thru water to the bottom of the bumper. I dont know if that would have done anything or not.
Old Aug 14, 2009 | 02:37 PM
97el's Avatar
Default Re: Is my clutch shot?
Sounds like it won't disengage. If the clutch was shot it would be slipping.
Old Aug 14, 2009 | 02:38 PM
theineffable's Avatar
try adjusting the clutch...
i think 7th gen civics have an adjustment screw under the pedal area?
Old Aug 14, 2009 | 02:47 PM
DC2AznCUddy's Avatar
dont alot of honda grinds in reverse???
my friends has 3 diffrent honda and each one grind in reverse and so does my
and when u were shifting w/o clutch was it going straight into a diffrent gear or only neutral??
Old Aug 14, 2009 | 03:31 PM
jdmfreak1992's Avatar
Well I don't don't think its clutch it sounds like a tranny issues. And I'm almost sure that trucker shifting isn't good for your syncros.
Old Aug 14, 2009 | 03:38 PM
85_305's Avatar
Yep.. like the pedal cant go down far enough. And about the slipping, thats EXACTLY what I thought. This clutch hasn't slipped on me once yet.
Actually, my previous hondas DID grind in reverse but not this one. I'm saying that when I try putting it in reverse it grinds because i'm only catching half the gear; the clutch wont fully disengage.
When I shift w/out the clutch, I can go thru all the gears. Its just a bitch if I have to stop since it wont go into first unless I'm stopped and I shut the car off.
The tranny is new and has shown no signs of error until this very day after work. Its something w/ the clutch or one of its systems for sure.
theineffable
I'll have to look at that.. but why would this not pose as an issue until today after work?? It's strange it came out of the blue. And I'm pissed.
Old Aug 14, 2009 | 04:44 PM
i think there's a nut that locks the pedal position...if it comes loose, things like that can happen...
Old Aug 15, 2009 | 05:14 AM
85_305's Avatar
awww snap. I'm gonna go check that out. I'll report back later. Thanks brah
Old Aug 15, 2009 | 05:07 PM
85_305's Avatar
No other input? I'm gonna check the adjuster out tomorrow, but what are the odds this is the clutch being blown?
Old Aug 17, 2009 | 10:57 PM
civic=goodgasmileage's Avatar
need a new clutch mate! same thing happened to me getting off work to. found out my throwout bearing, clutch disc, n pressure plate was all messed up when i took out my tranny to look at it. but it could be something else though.
Old Aug 18, 2009 | 08:02 AM
85_305's Avatar
Wow thats just wonderful man. I cant believe this ****ing thing. The clutch never slipped or otherwise that would tell me the clutch is going bad though, which really REALLY pisses me off.
Old Aug 18, 2009 | 03:58 PM
eviee1973's Avatar
To avoid grinding when going in to reverse, put trans in first gear, then syncros will line up, and it will easily slide into reverse.
Old Aug 18, 2009 | 04:02 PM
85_305's Avatar
your missing what I'm saying. This transmission does NOT grind ANY gears. but since it's been broken, I cant put it in ANY gear and have to start the car in first gear and "trucker shift" it. I can TURN ON the car in reverse, but I cant shift to it since the clutch or something is ****ed up.
But yes the 1st-reverse trick worked on my HX
Old Aug 22, 2009 | 01:48 PM
85_305's Avatar
Well I had 2 honda heads look at the car today. I drove like 8 hours both ways to meet them. They said they are 75% sure its the slave cylinder. But it COULD be the throwout bearing.
So on my trip home, I pull up to a red light. Shut the car off, but it in first and wait. Light turns green, so I start the car and take of in 1st gear. There is a slight, odd, clunking noise coming from engine compartment somewhere. I continue on. I pull up to another red light a few miles later. Go thru the same procedures, only this time as I"m pulling away, there is another metallic clunking noise (sounded like the motor slightly shifting or something I dont know) and now my clutch works fine! I drove home a few hundred miles with it working!!
What. The. ****. Is going on?
Old Sep 19, 2009 | 06:49 AM
sw1fty's Avatar
im having the exact same problem.... going to check the slave tomorrow and might try and adjust the pedal
Old Sep 19, 2009 | 08:12 AM
85_305's Avatar
Wow thanks for reminding me! Actually, what happened was driving thru the deep water (over the front lip almost half way up the bumper) had somehow caused the clutch or something to seize. After several HUNDRED miles of driving, upon pulling up to a red light, it out of nowhere started working again.
Old Sep 20, 2009 | 12:54 AM
sw1fty's Avatar
does anyone have any input as to how to fix this? i cant see what is wrong with mine, removed the tranny and the clutch/release bearing/flywheel are all fine.
i replaced the release bearing and rebuilt the gearbox 2000km's ago
problem happened 2 days after a bit of "spirited" driving
there were no signs until it suddenly started do the same thing as OP
HELP!!!!
edit: to clarify, the clutch pressure plate/disc was not replaced as it was only 20 000km's old at that stage
Old Sep 20, 2009 | 04:36 AM
sw1fty's Avatar
Never mind! Found the problem. The release fork had a big crack right on the pivot point. Don't know how i missed that...
Old Sep 21, 2009 | 10:03 AM
even if it's working again, bleed the slave cylinder...might want to spray some lube at it...
bleeding the slave on my old protege5 was really easy.
Old Sep 21, 2009 | 10:05 AM
just out of curiosity, did the clutch feel heavier when the release fork started to fail?
Old Sep 21, 2009 | 11:51 PM
sw1fty's Avatar
not noticeably heavier no
anyway bought a new one and is all going well now
renewed the hydraulic fluid just for the sake of it too.
cheers for your help guys
Old Sep 24, 2009 | 02:00 PM
Edgar @ Swapped's Avatar
Former Vendor
check your pedal position, this happened to me a while ago in my s13.
Old Sep 24, 2009 | 09:04 PM
85_305's Avatar
^thats right these cars have adjustable clutch pedals (though they aren't SUPPOSED be adjusted in the first place)
Old Sep 26, 2009 | 04:02 AM
sw1fty's Avatar
how do i adjust it exactly?
do u have a pic of the bolt?
Old Sep 26, 2009 | 09:07 AM
85_305's Avatar
Honestly I've never found it, but they claim there is a bolt near where the pedal attaches to the firewall. Thats about all I know man
