Oil smell coming from cockpit???
Old Aug 25, 2002 | 03:01 PM
Alaskan98ITR406's Avatar
New User
Default Oil smell coming from cockpit???
I just rebuilt my motor 20,000 miles ago with Spoon Sports JDM ITR Pistons (Stock Bore) and I use Redline 5w-30 oil. I burn about 1 quart every other day. I drive 39 miles to work and back and I have the JDM Final Drive, so I am in the higher RPM's on the highway. Where could this smell be coming from? I haven't done a CLT or taken off the intake to see if there is oil in the TB yet. Has anyone else had this problem? Any help on the matter would be greatly appreciated. Thanks!
Old Aug 25, 2002 | 03:08 PM
D's Avatar
D
Default Re: Oil smell coming from cockpit??? (Alaskan98ITR406)
1 quart every ~200 miles... is that correct?
Old Aug 25, 2002 | 10:35 PM
New User
Default Re: Oil smell coming from cockpit??? (D)
That is correct, + or - 20 miles. I will get CLT test done this week. Any suggestions on what else to check?
Old Aug 26, 2002 | 12:32 AM
CivicEK.PDX's Avatar
check your oil pan gasket and anywhere hondabond would have been applied.
Old Aug 26, 2002 | 06:30 AM
Christian's Avatar
Default Re: Oil smell coming from cockpit??? (CivicEK.PDX)
I would have to imagine that you are also blowing lots of blue smoke from your exhausr during hard acceleration. If so, sounds like your piston rings are shot. It maybe time for a rebuild . You'll have to overbore the cylinders and get new rings and pistons.
It will be expensive.....
GoodLuck
Old Aug 26, 2002 | 06:45 AM
uNF$@#!'s Avatar
Default Re: Oil smell coming from cockpit??? (Christian)
GoodLuck
considering a stock bore i would think it may be the piston rings as well.
Old Aug 26, 2002 | 10:51 AM
mugenracer's Avatar
Default Re: Oil smell coming from cockpit??? (Soup ****)
I had the same problem a while back, but only under hard accelerating, i changed the PCV valve and havent had the problem since!
Old Aug 26, 2002 | 11:37 AM
JPP's Avatar
JPP
Keep in mind that Redline oil burn at an alarming rate compare to other oil. Try Mobil 1 or anyother synthetic oil at your next oil change and see if it solves a part of the problem.
Old Aug 26, 2002 | 11:50 AM
Christian's Avatar
Default Re: Oil smell coming from cockpit??? (mugenracer)
He's burning a quart every 200 miles. He needs to do more than just change oil.
MugenRacer: Wow!!! Just replacing the PVC Valve fixed it? Are you serious? That actually could be my problem. I am going to try that tonight. I hope that works.
Christian
Old Aug 26, 2002 | 11:56 AM
JPP's Avatar
JPP
Christian
I did say "solve part of the problem". A falty PVC valve or busted oil rings could be the other parts of the problem (but there is no need for me to repeat what other people have said)
[Modified by JPP, 3:57 PM 8/26/2002]
Old Aug 26, 2002 | 02:21 PM
Chubz's Avatar
Default Re: Oil smell coming from cockpit??? (JPP)
CLT test is th eonly way to find out why your burning oil, it could be as simple as a bad PCV system. I was burning 1 quart every oil change. Did a CLT test and compression in every cylinder was over 300 psi....and leakdown test showed nothing.
Old Aug 26, 2002 | 04:53 PM
mugenracer's Avatar
Christian
sorry i meant i had the problem with the smell of burning oil in the car, changing the pcv valve cured that, but i wasnt burning oil, well not a quart every 200miles, more like a quart every 2-3k. I had the oil/comp rings plus all head seal/gaskets replaced to cure that. But changing the pcv valve did cure the smell in cockpit problem. I had the rings and head work done only a month or so back, i changed the pcv valve about 10 months ago.
r.etheridge
21
Feb 11, 2011 07:33 PM
ultraplayer26
12
May 27, 2010 08:42 AM
Jorsher
Sep 7, 2006 06:05 PM
Wazup
May 1, 2003 06:51 PM
lopey
Feb 5, 2002 09:46 AM
