What periodic tuning does an ITR engine need if used aggressively (autox, track, street)?
Old Aug 25, 2002 | 02:53 PM
rltrock's Avatar
New User
Default What periodic tuning does an ITR engine need if used aggressively (autox, track, street)?
What kind of periodic engine tuning is necessary for aggressive ITR use (track once a month, autox regularly and street driving)?
Timing? spark plugs? valves? anything?
Thanks!
Ron
Old Aug 25, 2002 | 04:10 PM
MK Ultra's Avatar
Default Re: What periodic tuning does an ITR engine need if used aggressively (autox, track, street)? (rltro
If it can break, burn, leak or work out of adjustment check it.
Old Aug 25, 2002 | 05:40 PM
nEoMuGen's Avatar
Just change the engine oil frequently. Ignition Wires/Spark Plugs every 7,000-10,000 miles, Fuel filters every 15,000mi, do valve adjustments if VTEC makes clicking noise. Timing can be check while you are doing a major tune up. Other than the above, ITR holds up fine for your tasks, maybe a stiffer engine mount and insert will also help.
I would be more concentrated on the wear of brakes/tires and routinely bleed the brake fluid and the clutch.
[Modified by nEoMuGen, 9:40 PM 8/25/2002]
Old Aug 25, 2002 | 06:00 PM
chad's Avatar
Moderator
i haven't changed my fuel filter in over 200k......120k with a stolen type r engine in it!
Old Aug 25, 2002 | 06:02 PM
B2FiNiTY's Avatar
Just do oil and filter every 3k. Usual maintanence, earlier if necessary.
Old Aug 25, 2002 | 06:04 PM
1GreyTeg's Avatar
A'yup!
A.
Depending Strongly on just how much abuse the car gets, you may be able to follow a modified Stock Manufacturers suggested maintenance schedule.
I do...
A.
Old Aug 25, 2002 | 11:54 PM
K1R's Avatar
K1R
dont forget the Tranny..
Old Aug 26, 2002 | 12:02 AM
Tommy_Gunns's Avatar
The only thing I fear is timing belt failure. Precaution wise, keep a close eye on your oil level and cleanliness. Clean oil is good oil...change it often vs buy expensive oil and change it less....if you can afford to change it often and buy expensive oil, more power to you.
Old Aug 26, 2002 | 12:05 AM
Smitdog's Avatar
Makes a difference!
Old Aug 26, 2002 | 02:02 AM
Maximus's Avatar
Makes a difference!
How many miles till you should change your tranny fluid?
Old Aug 26, 2002 | 02:09 AM
B2FiNiTY's Avatar
Book says 30k but I would do 15k.
Old Aug 26, 2002 | 03:22 AM
Dirt's Avatar
Uh, ok.
Uh, you should hear valve ticking at idle not in VTEC.
carlosd68
12
Sep 28, 2012 08:07 PM
tegra96
Mar 26, 2006 05:28 AM
rltrock
Aug 26, 2002 08:53 AM
TyperDude27
Apr 25, 2002 08:57 AM
