VSS help
Old Aug 25, 2002 | 02:36 PM
blufke's Avatar
Default VSS help
well, i removed my vss from my tranny(well, the part that just unbolts from the tranny) to clean it up once. it worked after that, then stopped working again. took it out to clean it, and the middle pin that gets corroded was loose. it was a little loose before. but it broke off during cleaning.
so i swapped on the one from my 92 vx, the motor that the broken vss from is a 94b18b, but it doesnt work. i thought that it should work, but just not well. it bolts on right, but the plug for the b18b clips on the vx one(but you turn it 180 degrees).
where can i get a new vss, or working one for my b18b, or what do i do to make the other one work.
Old Aug 26, 2002 | 01:20 AM
blufke's Avatar
Default Re: VSS help (blufke)
anyone?
Old Aug 26, 2002 | 07:23 AM
Civic1992DX's Avatar
can't you solder the connector from VX to the harness?
Yuri K
Old Aug 26, 2002 | 01:13 PM
blufke's Avatar
Default Re: VSS help (Civic1992DX)
ttt
Old Aug 26, 2002 | 11:56 PM
blufke's Avatar
anyone know where i can pick up a new/used vss for fairly cheap? and, anyone have any help on how to make the dseries one work on my bseries?
Old Aug 28, 2002 | 03:29 PM
blufke's Avatar
c'mon, someone knows, share.
724chris
Jan 13, 2010 10:22 AM
kartman
Jul 22, 2004 09:28 PM
