What advantages P72 ecu over stock??
Old Aug 25, 2002 | 02:34 PM
SiC CiViC's Avatar
Default What advantages P72 ecu over stock??
i just want to know what the advantages r in a jdm h22a with a p72(obd-I) ecu over the stock jdm h22a ecu i believe its obd-II
please help i dont know whether to put the gsr ecu in or keep the stock one
Old Aug 25, 2002 | 04:38 PM
satan_srv's Avatar
Default Re: What advantages P72 ecu over stock?? (SiC CiViC)
A stock gs-r ecu will run very lean, and I would not consider it unless you have someway to modify your fuel. Especially with the JDM H22a the 10.6:1 compression will make it worse. I would be very worried about detonation with the p72.
But a p72 can be easily reprogrammed (a la Hondata), so if you are planning to do that, a p72 is a good choice
Old Aug 25, 2002 | 09:16 PM
SiC CiViC's Avatar
Default Re: What advantages P72 ecu over stock?? (satan_srv)
i suppose ill keep the stock ecu for a little bit prob change to OBD-I p13
does anyone know a website that sells some good chips??? and what would u guys think is the best chip for the h22a???
crazychickenhead
Sep 22, 2009 08:14 AM
XLR8_HFX
Jan 8, 2006 09:02 PM
blackhawk
Feb 24, 2004 07:17 PM
