98 itr ac harness wiring HELP!!!
Old Aug 13, 2009 | 06:31 PM
I Kick Squirrels's Avatar
Default 98 itr ac harness wiring HELP!!!
I just picked up a 1998 itr shell about two weeks ago. The previous owner had a wire tuck done and obviously deleted the AC and other misc gismos. I have gotten all the wiring figured out so far that I need to get the car in working order. The only problem I have run into is the harness was cut that goes to the AC fan, AC pressure switch and the AC compressor clutch connector.
I have a ac harness from a 94 gsr that has 7 wires on the connector and none of the color match...which has two relays in the harness
I also have a ac harness for 00 integra and it has 4 wires on the harness and no relays inline with the harness
There is a good chance that this is a confusing A$$ post and I apologize for that .... If anyone can understand what im tryin to say and can be any help to me that would be AMAZING
thanks
Old Aug 13, 2009 | 09:28 PM
EM1 Loi's Avatar
Default Re: 98 itr ac harness wiring HELP!!!
thanks
i believe the relay is on the passenger side harness. not on the a/c harness. i would tell you 100% forsure but my R is still in paint.
Old Aug 14, 2009 | 10:43 AM
I just need the wire colors that are on the actual chassis harness that goes to the ac harness......wire colors and what they go to would be amazing.
Old Aug 16, 2009 | 05:54 PM
skippygsr's Avatar
bump because i would like to know as well
Old Aug 19, 2009 | 06:20 AM
well I figured it out on my own lol..
the previous owner that had the tuck done on it decided to cut the wires back pretty far and tape them up in the harness...so I didnt find the wires untill I pulled all the wireloom/tape off the harness.
I will post up some info when I get home
Old Aug 19, 2009 | 11:52 AM
andyt's Avatar
This might help....
_EF9
Nov 14, 2012 08:33 AM
boarderfatty
May 15, 2009 05:21 PM
(760)doogie
Jan 11, 2008 03:35 PM
Danger
Apr 26, 2004 03:50 PM
limegrnxj
Mar 25, 2003 07:10 PM
