heat shield on a resonator ?
Whats up guys,
just trying to figure out on my 95 civic if the heat shield on the top of my resonator is necessary?
only reason im asking is that its coming loose and making a bitch of a rattling sound so i wanted to get rid of it or fix it
what do u guys think?
Thanks.
Thanks.
i also here a little noise( a rattle) and i know its not from the resonator
i gotta find out what it could be... u guys know of anything else that would rattle on a honda.. generally on a revdown ude hear it.. i know its some metal but i dont know where :S
fak
fak
if your car isnt lowered,or if it is jack it up, get on the floor but not underneath and have some one rev the engine and try to look to see where its coming from. ****WARNING: READ VERY CAREFULLY**** if it has not been turned on in a LONG time and the engine is still cold then its ok to lightly touch your exhaust but it will only be okay to touch for the most one or two minutes after it has been turned on and if its been revved alot then just one minute. If you are going to touch near the exhaust manifold just dont do it at all. And about the heat shield a quick fix may be to get some metal wire, i forget the actaul name of it, and wrap that around your resonator, and again only do this when the exhaust is cold.
katzenjammer84
Honda Civic (2001 - 2005)
Apr 13, 2007 09:39 PM
