Fastest Way To Bottom 11s...heres the set up so far..
Old Aug 13, 2009 | 02:35 PM
SVT's Avatar
SVT
Default Fastest Way To Bottom 11s...heres the set up so far..
Looking to maybe build a big turbo car soon, if it fees'able?..Wonderinf If I can keep the trans in it now or not...looking to build like a 400+whp gt30 car this winter...or the quickest and easiest set up for my car... heres how she sits now...
1998 EJ8 coupe 120k on bodyb16a2 block
b18c pr3 gsr head (bent valve we think)
b16a2 valvetrain
b16a2 tranny
Civic SI pr3 pistons
8k miles on clucthmasters
fx200, if i remember right its kevlar.
apexi world sport coilover suspension
AEM pulleys
skunk2 upper control arms
AVID motor mounts
uerethane filled tranny mounts
J's racing carbon fiber intake
DC ceramic Header (rusty)
Thermal r&d full 2.5" exhaust
aem 255 fuel pump
440cc injectors
apexi VAFC engine controller
NRG quick release steering wheel hub
PERSONAL steering wheel
civic type r shifter
Acura NSX brake Calipers on 11.5" rotors
braided steel lines
HAWK pads
Acura Integra Type R 1" Brake master cylinder
civic type r headlights
civic type r grill
civic si cluster
8200 redline
40k on this build
Just looking to go low low 11s sit be able to somewhat daily drive it if I had too... put it on a tire and the track and go fast, but pretty much a car I can just drive around and whoop upon unexpected cars on the streets... I want to go with like a b18c( or is that swap even necessary setup with a gsr/ls trans, and good built head and a gt30r turbo or something similar.... whats your guys opinion? I have been trying to do some resreach on here but people are so all over the board with set up ideas. I have been a mustang guy my entire life but for some reason these little car are pretty cool. I just bought this car as it sits...wondering where I should go from here... thanks guys...(but like I said Ive only known mustangs so the past 2 weeks ive been spending alot of time online trying to resreach this build, and how much it will cost) thanks again guys
Old Aug 13, 2009 | 04:01 PM
dantamparacer's Avatar
Default Re: Fastest Way To Bottom 11s...heres the set up so far..
i have seen a B16 block with a B17 crank break 600+hp and 300+Lbs, but that was in a magazine i dont know specifics on it or what type of fuel. Common guys i cant wait to hear the trash from seeing something in a mag atleast i can admit it! There is not much else to do in Iraq durring my free time.
Back to the questions... I would run a B18c with a LS tranny for longer gears
Old Aug 13, 2009 | 04:52 PM
PyroProblem's Avatar
LS/VTEC or B20/VTEC because they are fairly inexpensive.
GT30 or 35 should be PLENTY for a FWD street car...
Shorter gears are faster in most cases...
Old Aug 13, 2009 | 06:28 PM
sc4dr's Avatar
The type r headlights should be all you need to acheive your goal.
But no seriously fix your bent valve and you're there!
Old Aug 13, 2009 | 06:30 PM
tegman23's Avatar
If you build the car right the first time you shouldnt have any problems daily driving the car..I pretty much drive my car every day, unless an issue comes up...lol
kyleeuuu
Feb 5, 2013 03:07 PM
sa90eg
Northern California (Sales)
23
Sep 16, 2008 08:43 AM
ixoiiiiviviiivi
Suspension & Brakes
Sep 13, 2008 12:09 AM
-=GSRpwrdB16=-
21
Feb 2, 2007 03:07 AM
