Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
D16W1 Project Crover Stage2 Camshaft install
Old Aug 13, 2009 | 10:31 AM
despe's Avatar
Default D16W1 Project Crover Stage2 Camshaft install
Dc 4-2-1 Ceramic Race Headers
AEM V2 intake
Apexi N1 catback
Crower Stage2 Camshaft
Crower Stage2 Springs
AEM Tru-Time Cam Gears
AEM ems 30-1030
despe's Avatar
Default Re: D16W1 Project Crover Stage2 Camshaft install
resimler burda arkadaşlar
Old Aug 13, 2009 | 10:32 AM
despe's Avatar
http://videos.streetfire.net/video/D...ge2_701236.htm
http://videos.streetfire.net/video/D...Rpm_701237.htm
Old Aug 13, 2009 | 12:18 PM
toyomatt84's Avatar
Sanji
Nice work, but just as a forewarning... that throttle body spacer isn't going to do anything for you because the fuel injectors are located near the intake ports on the head. The atomization of fuel won't change at all with the spacer that far behind.
PS. Your video links need editing.
Old Aug 13, 2009 | 02:36 PM
jdmfreak1992's Avatar
Your links are dead but nice job. Any power numbers for us?
Old Aug 13, 2009 | 11:06 PM
despe's Avatar
soryy new links
Old Aug 14, 2009 | 05:10 AM
Curiouz_G's Avatar
id say youd probably get around 130-140whp max. this is pretty much bombermans old setup, cept without the kpro (your using AEM EMS) and his JDM Fab Tech intake manifold.
Old Aug 14, 2009 | 11:07 AM
Hmmm well thats not bad for a d17 I figured around 125 at the most. It idles really nice how did the EMS work out for you?
Old Aug 17, 2009 | 06:05 PM
redb16coupe's Avatar
any updates? new videos in action?>
Old Aug 18, 2009 | 01:58 PM
wikkaco0's Avatar
New User
Quiet valves (or is it the camera). What did you set the lash clearances to?
I have a similiar setup. However, like bomberman, running Kpro.
Old Aug 19, 2009 | 11:15 AM
EternalBlueEX's Avatar
Videos of it hauling ***!
Old Dec 22, 2009 | 08:21 AM
Jason Liu's Avatar
[QUOTE=despe;39611685]AEM Tru-Time Cam Gears
AEM Tru-Time Cam Gears How much money?
Old Dec 22, 2009 | 07:36 PM
bomerman19's Avatar
yeah that is pretty close to my setup cept intake mani and I built up the bottom end a bit more and k-pro. oh the cam gear won't do anything on a single cam but props on a nice setup I bet you will have fun
Old Dec 23, 2009 | 10:48 AM
2002civicrider's Avatar
Very nice setup. Interested in the numbers. You will most definatly hit higher than 125. Here's my dyno graph:
I hit that with full header back exhaust, intake, stage 1 cam, and on the stock ecu with no tune (since it can't be tuned in the first place). I'd imagine anywhere from 140-150whp is what you will hit. It'll be fun to drive afterwards for sure.
Old Dec 24, 2009 | 12:49 PM
skatejosh369's Avatar
Not a bad little set up.
If it where me I would have thrown in some head studs while I had the head off the motor.
bomerman has rod bolts in the bottom end as well.
Id aslo maybe step the injectors up to some rsx injectors.
Old Dec 24, 2009 | 12:59 PM
RACEPAK's Avatar
nice setup,
good parts
Old Dec 24, 2009 | 01:11 PM
Harlowe's Avatar
Function>Fashion
old thread is old
projectef
Jul 7, 2009 05:44 PM
1baddturbosi
May 25, 2007 06:21 PM
jdmtheory2128
Jan 28, 2007 01:23 PM
mrmrry243
Honda Civic (2006 - 2015)
Dec 27, 2006 03:59 PM
