tension on the timing belt?
having trouble with the tension on the timing belt any hint would help....also someone said lining the two lines up on the head is for the 1.5 and would make the d16 1 tooth retarded is that right?
Not exactly sure what the tension problem is that you are experiencing.
The Helm manual and factory service manual are your best bet for the best answer.
I hear you can find them on the internet in PDF form.
My guess is that you are forgetting to rotate the crank counter-clockwise 3 degrees after putting the belt on.
Last edited by 4drEF; Aug 13, 2009 at 12:39 PM. Reason: had put '3 revolotions' instead of '3 degrees'
Install belt with tensioner held in "loose" position by tensioner bolt. > Loosen tensioner bolt so spring can take up the slack. > Rotate engine CCW a couple of turns. > Tighten tensioner bolt.
The manual says to loosen the tensioner and rotate the crank counter-clockwise 3 degrees
Which is about 3 mm. then tighten the tensioner.
I will always rotate the crank a few times around just to make sure it is going to have clearance and again turn it counter-clockwise.
annette'shonda
Apr 8, 2013 12:39 PM
Haleiwa-Brando
Mar 31, 2006 07:10 PM
