Torque Dampner for B18 EF?
Cant seem to find one anywhere. I have one now but it was ment for a B17 DB Teg so the brackets don't match up. What would be best for the money and where could I find them?
If you want to fix the problem, you should fill your engine mounts with 3m window weld or some other polyurethane stuff in a tube. You can do that for like $20 and fix the problem..
I don't think anyone makes a torque damper for the EF, and if so, I have never seen one that wasn't custom. My only guess would be Password JDM, but they only have them for a few vehicles. My opinion would be to just adapt what you have to work, or go the 3m window weld route.
There is no reason for them, it's a bling toy.
Don't stress about it, get some good mounts.
If you must try fabbing something up or customizing one.
like everybody has said just get some decent mounts or fill your mounts with window weld, and if its still moving too much make or pay someone to make a custom front mount.
dampers dont look usefull in the least bit, they're tiny, the mounting points are terrible, and they only work in one direction. just more ricer bling.
Gotcha, nothing wrong with my mounts, just more of a curious thing. Since I already have a dampner, I've tried to see about fabricating something so I can use it. I figure I might as well do something with it since I already have it.
MyLilCivic
Apr 12, 2008 12:44 PM
rafimos
Oct 13, 2006 10:39 AM
