Starving for fuel!
Old Aug 25, 2002 | 01:26 PM
Yuleluder's Avatar
Default Starving for fuel!
Okay heres the deal, I recently got my head back from Gude performance, they bored out my throttle body and ported + polished my intake manifold. I've got an intake along with an exhaust. I know that she's breathing a hell of alot better, but now she's starving for fuel. My plugs are white with small deposits on them, a sign of detonation. I've got a V-AFC, but what I need to know is how can I richen up the air fuel mixture? I haven't done anything to the fuel system. What is the most important step when trying to richin your fuel mixture?
Old Aug 25, 2002 | 02:29 PM
PrecisionH23a's Avatar
Default Re: Starving for fuel! (Yuleluder)
since you have the v-afc you can increase fuel using the settings, are you familiar on how to program it? the best thing to do would be take it to a dyno though so everything runs great.
Old Aug 25, 2002 | 02:37 PM
RAB's Avatar
RAB
Default Re: Starving for fuel! (GudeH23a)
I have a book on exactly what you're talking about, i.e. tip of spark plug color, rich and lean fuel mixtures. I haven't really studied it yet just read on it. YEP i know it doesn't help but what the hey.
At least you called gasoline Fuel on that.
Old Aug 25, 2002 | 02:46 PM
Yuleluder's Avatar
What's up with those 310cc injectors? I've been increasing the it with the wide throttle it seems to run better but she's still a little choppy. I need to find someone around here with experience tuning on a dyno!
Old Aug 25, 2002 | 02:57 PM
yes you do.
Old Aug 25, 2002 | 04:54 PM
cybercrx00
Guest
Posts: n/a
even more so than finding a dyno would be finding a good wideband O2 to tune on. if you can find someone with one.
Old Aug 26, 2002 | 09:11 AM
ViZ's Avatar
ViZ
Default Re: Starving for fuel! (cybercrx00)
you can also get a fuel regulator but the only way to tuneit right is on a dyno...
Old Aug 26, 2002 | 09:47 AM
714's Avatar
714
Default Re: Starving for fuel! (ViZ)
try A&H motorsport in willow grove, I dont think they have a dyno, but may be able to point you in the right direction
Old Aug 26, 2002 | 10:06 AM
bgod's Avatar
Default Re: Starving for fuel! (Zottyzot)
with the stock ecu at stock settings you should not be running dangerously lean as you mention. white plugs?
just richen the whole mixture at wot and part until you can get some dyno time.
Old Aug 26, 2002 | 10:07 AM
Buckkaaaa!!'s Avatar
New User
yeah pick up an adjustable fuel regulator and maybe a fuel pump..... you can set your base pressure higher and lean it out some with your VAFC
Sci_v_icI
12
Dec 23, 2005 06:23 PM
c1civic
May 30, 2004 10:21 AM
oryanh
Jan 1, 2002 11:36 AM
maximedx
Dec 4, 2001 08:53 PM
Kellindal
Sep 9, 2001 10:45 PM
