question on ecu codes.....
Old Aug 25, 2002 | 12:47 PM
brian.edge's Avatar
Default question on ecu codes.....
ok i have a b17 in my 90 si.......i have had it in there for a couple months now...but never with VTEC hooked up....cause it has always thrown a code...we got it down to the knock sensor.....i re-placed that now it is throwning new ones...
code 9-cylindor position sensor and code 21-VTEC soleniod valve....
do any of you have any suggestions as to what might be causing my ecu to throw these codes?
could it be that i just need a whole new ecu???
please help this is getting really frustrating
Old Aug 25, 2002 | 12:56 PM
00WhiteEKy's Avatar
Default Re: question on ecu codes..... (lilhibbs)
remember that long blinks are 10 and short blinks are 1. U probably know that, but some people don't, and they complain about the wrong codes. good luck.
Old Aug 25, 2002 | 12:57 PM
brian.edge's Avatar
Default Re: question on ecu codes..... (92hatchy)
yep i know that...thanks man
Old Aug 25, 2002 | 03:51 PM
djay86's Avatar
i had a VTEC engagement problem whenever i had my lights on, and sometimes even when i didnt, i found out my negative battery ground was about to fall off! Problem solved! Check your grounds!
Old Aug 25, 2002 | 07:42 PM
brian.edge's Avatar
Default Re: question on ecu codes..... (djay86)
TTT....come on guys need some help here
Old Aug 28, 2002 | 07:34 PM
brian.edge's Avatar
come on guys....someone has to know what i need to do........TTT
please help me out
SolScifen
May 19, 2013 11:35 AM
-KangaRod-
Jun 22, 2005 05:45 AM
gsrcivic619
Mar 24, 2004 10:22 PM
HarryB
Jul 11, 2003 11:44 AM
RoaringTurtle
18
Aug 5, 2002 01:17 PM
