EG half-rad in EF - searched
Old Aug 12, 2009 | 08:15 PM
Canadian_EF's Avatar
Default EG half-rad in EF - searched
Sorry if this has been covered before...
I searched, couldn't find any good info...
Is there a way to make the EG half-rad fit without the "gangsta lean" that I have heard so much about?
Old Aug 12, 2009 | 08:19 PM
Civicfanatic_09's Avatar
Default Re: EG half-rad in EF - searched
My buddy made custom mounts at the bottom to lower his with diamond plate the made a custom top bracket, and cut some webbing out of his hood. It fits okay.
Old Aug 12, 2009 | 08:43 PM
Clipsed's Avatar
I made my own traction bar, mine sits PERFECT...
You want it to fit right with the stock cross member, it ain't gonna happen because it is taller.
Old Aug 12, 2009 | 08:47 PM
thanks, that is what I needed to hear... won't work with stock parts.
Old Aug 13, 2009 | 03:39 AM
jhammond_82's Avatar
Reject Papi
why can't you just use that one bent radiator bracket? i'll try to find a pic of it. you can always use a good drill and some tapcons to put that bitch in there. thats what i'm planning on using.
Old Aug 13, 2009 | 03:41 AM
Reject Papi
haha, here ya go. http://www.robearracing.com/cat_radiator_bracket.cfm
and some have a bigger bend than others, like this one. http://cgi.ebay.com/ebaymotors/Benen...Q5fAccessories
Old Aug 13, 2009 | 04:31 AM
dephtone's Avatar
On my first experiment this without using a traction bar, I cut part of the buttom core support out so the radiator sat a little lower in the car, only had to lean it a little bit for it to fit, or you can smash in part of the hood.
As you said before, not with stock parts, you can make it look pretty decent but nothing like it would look with a traction bar setup. And for the extra 250 bucks, it's worth it to get the traction bar that has 1/2 radiator mounts and the clearance for a larger size header, i.e 4-1 or turbo downpipe.
Old Aug 13, 2009 | 08:01 AM
Clipsed's Avatar
wow you idiot... you have no idea what you are talking about... That is the top stay bracket... He want's to know how to fit the radiator in.
Old Aug 13, 2009 | 08:05 AM
sde780's Avatar
I'm doing the gangsta lean on mine lol
Old Aug 13, 2009 | 11:47 AM
Reject Papi
wow, i'm an idiot. i've been called alot worse, by more important people than you. its cool.
Old Aug 13, 2009 | 03:37 PM
Clipsed's Avatar
my bad on the name calling, I was tired as fawk, also I don't care if you think I am important or not. But did you actually understand what his question was? You posted him a link to a top mount radiator stay. That doesn't help him if the radiator won't fit with stock parts and no "gangster lean"
runghostrun
Oct 21, 2009 01:39 PM
superhatchbackbros
18
Jul 28, 2008 12:35 AM
dravesef
11
Aug 10, 2006 01:40 PM
jdm Ef-9
Oct 25, 2005 07:58 PM
technine
14
Oct 3, 2002 07:06 AM
