Interesting ABS Light issue
Old Aug 12, 2009 | 07:38 PM
noizivision's Avatar
New User
Default Interesting ABS Light issue
Since I've had my '92 Prelude (about 2 years), the ABS light has come on after about 5 km/hr. At first, I thought this was to tell me that ABS was working...until one day, I tried to rush a light at a bridge and slid right through...stopping just at the sidewalk on the other side (the only thing between me and the guardrail). I guessed at that point ABS light ON = BAD.
This week though, the light comes on when the key is turned on, but once the car is started, it stays off. I thought maybe this was a sign that whatever was stuck or dirty is finally freed/clean, but when I tested the brakes on the wet pavement, one of the wheels locked up and skidded.
Does that make any sense? One thing I did notice is there's a little squeal when I back-up now...as if metal is pressing against the rotor on the driver side front...but when I give enough pressure on the breaks, the squeal stops. Haven't pulled the wheel off yet to take a peak, but just thought I'd ask if anyone has any advice.
Thanks,
Noizi
Old Aug 12, 2009 | 11:38 PM
Kronn 98SH's Avatar
Default Re: Interesting ABS Light issue
The noise sounds like your pads are running thin. There's no telling on the ABS since the code wasn't pulled.
Old Aug 13, 2009 | 12:40 AM
ArmaanOG's Avatar
sucks my abs lights on also and i slid the other day but when its dry my drilled and slotted brakes stop on a dime
laurn
Suspension & Brakes
Feb 18, 2013 07:30 AM
doingthemost
Feb 17, 2013 08:06 AM
94coupeNA
Jan 26, 2006 12:56 PM
