Wiring Problem,Starter, Lights,Signal Lights not working
Old Aug 12, 2009 | 05:06 PM
hondacrx_gnvl's Avatar
Default Wiring Problem,Starter, Lights,Signal Lights not working
Hey Forum,
I own a 1989 Honda Crx Si. D16A6
I pulled out the Engine and rebuilt the Engine and Turbocharged the Engine.
Last week i put the Engine back in the Car.
I hook up the Wiring. And try to Crank the car but the car won't start(timing off). I stop working for the day and unhook the Battery. Today i continue to work on the Car and hooked up the Battery, but now the Starter wont turn, Signal lights, Head Lights, turn signals, inside lights, Radio don't work no more. The Battery light and brake light stays on even when i turn the key on off and remove the Key. I checked all the fuse inside an outside everything looks fine. I checked the plug ins they are fine to. I didn't change anything on the Wiring harness which is the original factory, with the pm6 ecu. Does anybody have an idea what the problem is?
Thx torsten
Old Aug 12, 2009 | 09:44 PM
Sl1ck09's Avatar
Default Re: Wiring Problem,Starter, Lights,Signal Lights not working
your starter might be stuck. give it a good tap and get someone to start it at the same time.
also double check to see if you have 12.6v+ on the batter.
what you could also do is just put booster right to the starter
hope this helps im haveing same problem with starter. but all my lights work
Old Aug 13, 2009 | 05:46 AM
thx for the answer. I try to start with a Battery booster it will not start. i took out the starter and took to advance the start is fine.
Thx Torsten
Old Aug 14, 2009 | 09:54 PM
enigma2446's Avatar
try switching out the main relay and some other ones around it
Old Aug 16, 2009 | 10:28 AM
Ludador's Avatar
New User
You might want to make sure all grounds are connected and also make sure you didnt accidentally pinch or pull some wires while you where removing / installing your motor.
Hope this helps !
Gwyn'sCRX1990
Oct 2, 2014 06:07 AM
RanCRX
20
Jun 27, 2007 12:25 PM
96hbdx
Apr 27, 2002 05:40 PM
