Suspension setup 98 prelude
I just picked up a GC/koni setup 350/450. Which I believe should work well to keep the weight from transferring to the rear. However I am unsure what to set the shocks at, full stiff or full soft. Also if you believe the spring rates may need changing i would appreciate your input.
