wrong control arm?
so heres the story, i put on the wrong control arm in my 94 civic ex. my old control arm has the hole for the sway bar, the new one doesn't. is it still safe to drive even though the passenger sway bar isn't connected to the control arm?
as long as the control arm bolted in fine.. you should be safe to drive. i would disconnect the swaybar link from the other control arm so you don't risk the end of the swaybar hitting the control arm in a corner..
If you plan to get the correct arm, leave the swaybar in. If you don't care, you may want to remove it but it isn't necessary.
EdSales
Apr 7, 2010 07:03 AM
dc2leftovers
Jul 24, 2009 12:27 PM
agent marlon
Nov 11, 2002 04:41 PM
