WA 2001 gsr k24a2 tsx hre mugen arc balling track car
Old Aug 11, 2009 | 11:10 PM
- LoL - db8's Avatar
Default 2001 gsr k24a2 tsx hre mugen arc balling track car
http://www.superstreetonline.com/fea...gsr/index.html
I BOUGHT THIS BRAND NEW IN 2001 OFF THE LOT. CLEAN TITLE. Never in a accident.motor has 2500 miles. this was a trainwreck motor from nikos. I dont ever drive this car. Its ready to be tracked. Spent upwards in the 50000.00 range. The fuel system alone was 2500. the wheels were 6000. I'm asking 25000 obo as it sits. Will part it out any way you want. Will take a stock car and cash for trades. Will sell just the shell or just the swap or whatever. We can make this work for your budget
2001 Acura Integra GSR - Keep It On The DL
Under The Hood 2.4L naturally-aspirated K24A2; Hasport EGK1 mounts; DTR 2.4L large tube header; Custom 3" exhaust; Hybrid Racing PNP K20 engine harness; Yeeserious plumbed and shaved RBC manifold, shaved valve cover; Karcepts throttle body adapter; Aeroquip starlite hose; Team 2to custom-shaved engine bay, wire tuck, brake line tuck; Jiffytite quick disconnect fittings; ARC Skyline oil cooler; Mugen oil filter; Fuel lab fuel filter and fuel pressure regulator; AEM fuel rail; ; Samco radiator hoses; Visteon radiator; Sard oil cap; Marshall fuel gauge; Alloy Racing catch can; Vision test pipe; Walbro 255 fuel pump; Spoon Sports radiator stay; Custom intake with AEM bypass; K&N air filter and catch can breather; NGK spark plugs
Drivetrain Exedy Stage 2 clutch; Karcepts shift mount kit
Brains Hasport/Hondata K-Pro
Stiff Stuff Function Form Type 2 coilovers; Function7 rear lower control arms; ITR front sway bar; Comptech rear sway/tie bar combo; Skunk 2 camber kit front and rear; Summit 4pt rear strut bar; JDM ITR 4X114.3 suspension conversion; FullRace traction bar (track)
Stoppers ITR front calipers and rotors; Hawk HP brake pads; ARP extended wheel studs
Rollers 15inch 4x114 steelies
Outside Audi TT Brilliant Red paint; C-West front lip, side skirts, carbon-fiber hood; ARC front splitters; Z spec carbon-fiber front canards; JDM front end conversion; J's Racing fender flares; JDM HOP window visors; Mugen trunk latches; VIS carbon-fiber trunk; Custom side mirrors; Shaved door moldings; Rear door handles all around (keyless); Moroso battery kill switch mounted in trunk; Remote battery terminals mounted in taillight
Inside Mugen door sill plates, shift ****, pedal set, DC5R dead pedal, ECU stay, gauge cluster, Personal steering wheel, ; Custom suede door panels, head liner, pillar covers; Odyssey PC925 battery in trunk; Circuit Hero shifter; HOP personal box, clock delete, airbag delete, radio delete, armrest delete; SRR ignition switch; ; Splash short steering hub; SPA tachometer
Old Aug 12, 2009 | 10:40 AM
Default Re: 2001 gsr k24a2 tsx hre mugen arc balling track car
fsfcdc
Old Aug 12, 2009 | 11:47 AM
srt4mike's Avatar
Old Aug 12, 2009 | 09:09 PM
tomgrom's Avatar
Sick!
Old Aug 13, 2009 | 06:01 PM
wdc
Old Aug 13, 2009 | 06:07 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Sick 4 door.
Old Aug 14, 2009 | 04:30 PM
fvfe
Old Aug 14, 2009 | 05:40 PM
ALLBEAST91DA6's Avatar
bump..
Old Aug 18, 2009 | 12:01 AM
h5hb5t
Old Aug 20, 2009 | 10:13 PM
hyh
Old Aug 23, 2009 | 09:03 PM
recvwrvc
Old Aug 29, 2009 | 09:05 AM
erver
Old Sep 1, 2009 | 11:18 PM
fyvgbh
Old Sep 2, 2009 | 01:08 AM
Mr.Lau's Avatar
nice........
Old Sep 6, 2009 | 09:27 PM
gtbvtrv
Old Oct 14, 2009 | 02:22 AM
hgj
Old Oct 14, 2009 | 02:54 AM
Arct's Avatar
very nice 4dr
Old Oct 14, 2009 | 09:26 AM
thanks
Old Oct 14, 2009 | 10:20 AM
denverjdm's Avatar
Loved
holy sedan!
Old Oct 16, 2009 | 07:39 AM
acsac
Old Oct 19, 2009 | 11:35 AM
vcwdvd
Old Oct 21, 2009 | 04:47 PM
Originally Posted by - LoL - db8
vcwdvd
Old Oct 21, 2009 | 04:48 PM
SiDaddy's Avatar
it up
Old Oct 28, 2009 | 08:48 AM
FWRV
Old Oct 29, 2009 | 09:45 PM
cvgn
