EK9 Pistons in EK4
Old Aug 11, 2009 | 10:44 PM
Way2fst4u's Avatar
Default EK9 Pistons in EK4
Hey guys!
Can I put my b16b (PCT) pistons in my b16a2 safely?
Or do I need a engine managmentsystem as Hondata/Crome and so on?
Old Aug 12, 2009 | 06:12 AM
GEN2 LS's Avatar
Loved
Default Re: EK9 Pistons in EK4
yes you can, b16's have a far smaller stroke than gsr's and ls's your compression ratio will be no where near as high as 1.8 motors. cp ratio should be right at 11:1. you should always get your car tuned crome will do the job for something so basic.
Old Aug 12, 2009 | 09:24 AM
Way2fst4u's Avatar
Okey.
I`m going to a trackday in the end of the month, and I`m thinking about putting them in this weekend.
So, just to be sure: I can put these in and drive safely without tuning?
Anyone here who has done the same thing?
Old Aug 12, 2009 | 07:32 PM
2.0|hybridHatcH's Avatar
my suggestion is no it is not safe. higher compression and stock valves and rods can lead to a blown motor. my cousin did this on a gsr and now his rod is sticking out of his block.
Old Aug 12, 2009 | 10:57 PM
Way2fst4u's Avatar
But I do not have a GSR! I have a std Civic 1,6 DOCH VTEC with PR3 head
Old Aug 13, 2009 | 09:32 AM
GEN2 LS's Avatar
Loved
Originally Posted by Way2fst4u
Okey.
what ecu does your car currently have? I would say NO to taking the car to the track you need to get a tune.
Old Aug 13, 2009 | 09:58 AM
dlaub25's Avatar
http://www.zealautowerks.com/bseries.html
Put your specs in there. It says your pistons will be out of the hole. It also says your CR is 11.91:1.
Old Aug 14, 2009 | 12:45 PM
Way2fst4u's Avatar
Again there is different opinion on everybody?
I need a solid answer.. Can someone help me?
Old Aug 14, 2009 | 01:40 PM
88Hatchy's Avatar
You can physically put the CTR pistons in a B16a, and it will most likely start. You WILL run into problems with engine longevity without a good tune. The engine may not last more than one full throttle run. It would be a very bad idea to go to a track day with CTR pistons in a B16a without a tune.
Old Aug 15, 2009 | 05:32 AM
Way2fst4u's Avatar
Thank you..!
.adam.
Mar 2, 2007 03:39 PM
Nextelbuddy
May 9, 2005 07:42 PM
Hatchbizzack
10
Jun 30, 2004 12:21 PM
