Integra coilovers compatible with civic?
Old Aug 11, 2009 | 04:01 PM
8OOSTED's Avatar
Default Integra coilovers compatible with civic?
I have a set of eiback ground controls for a 98' GSR and I was wondering if they would be compatible with a 98' Civic by any chance?
Thanks!
Old Aug 11, 2009 | 05:40 PM
808DA's Avatar
Default Re: Integra coilovers compatible with civic?
Thanks!
as long as the coils sleeve slides over the shock body, it should work. just make sure you use the rubber o-rings around the shock body so that the sleeve does not move around.
Old Aug 11, 2009 | 06:11 PM
jhammond_82's Avatar
Reject Papi
they should fit.
Old Aug 11, 2009 | 06:19 PM
Blue99teg's Avatar
I believe you also need Integra LCA's.
Old Aug 11, 2009 | 08:12 PM
Reject Papi
why? the rears are the same as far as i know. the front is the only difference. but, i'm not sure about those years for sure. for my da, i had to use eg front forks. not sure about the dc/ek chassis. but the rears i would think are the same. not 100% though.
Old Aug 12, 2009 | 04:28 AM
1bad-eg's Avatar
Yes they fit.
Old Aug 12, 2009 | 10:09 PM
dantamparacer's Avatar
they will fit i have dc suspention on a crx
Old Aug 12, 2009 | 10:14 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Yes. They will definately fit.
Old Aug 13, 2009 | 11:14 AM
kojack_0's Avatar
2x
cyclotegra
Suspension & Brakes
Jan 29, 2012 08:54 AM
DFW
Suspension & Brakes
May 7, 2006 05:46 PM
DeDonDeRosa
Mar 29, 2005 07:59 PM
gsr98teg
Sep 6, 2004 07:02 PM
Jaydo
Dec 9, 2003 07:50 PM
