Car Suddenly won't Crank at all
So last night i fixed ignition timing, Bolted everything back up let it run for a couple of minutes turned it off and washed the cars.
Came back to the car, started up quick we went around the block came back parked it the negative terminal came off but doesn't look like it hit anything(Could be wrong), car was still running when it came off. So i just plugged it back in and turned it off, then came back a short while after and it wouldn't start.
All lights, Interior Exterior work, main relay was resoldered since i though that was the cause but it clicks three-four times really fast when i turn the key. The car does not crank at all, when i say that i don't mean it doesnt turn over i mean doesnt even crank.
Anyways hope someone can help me with this! Thanks!
Nope brother, just checked them all with a multimeter, however my brother's 3000GT has a fuse on the starter, our should have one aswell right?
Well i checked everything and it seems good, i did however find two wirelooms that had some brackets on them, didn't seem like grounds and the car did start fine without them bolted it up the problem persists.
Sucks, meng. I was going to smog within the next two days to get it on the road again too.
Romodavid15
21
Aug 21, 2008 10:07 PM
thecorey
Jun 8, 2003 08:22 AM
