91 civic d15b
Old Aug 11, 2009 | 12:08 PM
E9CiViC1F's Avatar
Icon3 91 civic d15b
Okay heres my setup....JDM D15b Block(Roughly 10,000Miles), D15b2 Head(Non Vtec)(Unknown miles), MPFI Swap...Ive been haveing 2 error codes recently. First being code 9(TDCC Sensor), and code 15(Ignition Output Signal). What would be the cause of these codes and what actions should i take to fixing them. Any help would be much apreciated. Thanks
Old Aug 11, 2009 | 12:10 PM
dephtone's Avatar
Default Re: 91 civic d15b
Swap out another distributor, you are using a distributor from an Si correct not your DX one?
Old Aug 11, 2009 | 12:11 PM
E9CiViC1F's Avatar
Ive got the TD-02u Distibutor from an Si and the PM6 ECU
Old Aug 11, 2009 | 12:21 PM
dephtone's Avatar
Do you have another distributor laying around by chance? Both of those codes come from things in the distributor.
If the car was running fine before, then it sounds like you need a new dizzy.
Old Aug 11, 2009 | 12:26 PM
E9CiViC1F's Avatar
It was running fine before yeah with no codes but then the Code 9 came on and my tranny went out so im still in the process of fixing it then the code 15 appeared. So both of these codes the dizzy would have something to do with? Could wires be grounding out or showing and messing up the signal?
Old Aug 11, 2009 | 12:33 PM
dephtone's Avatar
Yes code 15 is the ignitor in the dizzy and code 9 is the cylinder position sensor.
Here is the factory service manual for code 9 and code 15. This will tell you exactly what to do and if somethings wrong, it will tell you what to replace.
Hope this helps you.
File Type: pdf
File Type: pdf
Old Aug 11, 2009 | 12:52 PM
E9CiViC1F's Avatar
Alright thanks ill give it a try and let you know how things worked out. Thanks again
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
EFjoe91
Apr 3, 2016 04:36 AM
b16a1eg6
Jan 17, 2007 03:32 PM
turbob18si
Dec 3, 2006 04:02 PM
itsmebeaner1987
Oct 21, 2004 01:52 AM
