help with zc starter!! what to use
Old Aug 11, 2009 | 09:43 AM
patrickstar's Avatar
Default help with zc starter!! what to use
so i have a sohc zc motor and i just purchased a starter for a 91 si motor. i compared the two and they look completely different. the zc is shorter and connections are in different places. can i still use it or do i need a different one? thanks guys
Old Aug 11, 2009 | 11:10 AM
Default Re: help with zc starter!! what to use
alright i just tried it, and the drive of the starter is too long. eh. i searched and everyone says all d-series starters work. why is this not fitting?
Old Aug 11, 2009 | 11:20 AM
nvm its not too long, i just realized the starter wont go in all the way because the tranny or something prevents it from going in straight.... what do i do now? lol
Old Aug 11, 2009 | 11:28 AM
well right now i just flipped the starter so i guess its upside down? i have two efs so i looked at the starter on my other one, and the connections are toward the front of the car. on the one im working on, i have flipped it so the connections are toward the rear of the car. is this ok? im not gonna start it until i get confirmation haha.
Old Aug 11, 2009 | 11:38 AM
4drEF's Avatar
Keyboard Humorist
Not sure about the SOHC but on the DOHC I was able to use both my stock LX automatic starter as well as an Si starter.
You sure you got the right year starter? Thinking you might have gotten a 92+.
Best advice I can offer is to take the bad one to the autoparts store and start comparing them until you get the right throw.
Old Aug 11, 2009 | 12:06 PM
im sorry im sorry haha.
well i got the starter on and i bolted everything up and i started it. it started but at start up, i hear a noise from the starter! its the sound you get when you try to turn the key on a running car. help? i search and saw it could be the flywheel?
Old Aug 11, 2009 | 03:17 PM
EF-Devotion's Avatar
what trannny are you running? use same starter as the tranny.
Old Aug 11, 2009 | 03:41 PM
4drEF's Avatar
Keyboard Humorist
turn the flywheel a little by spinning the crank. You can do this by turning an accessory pulley - usually it won't slip and the crank will turn.
Might be the flywheel has teeth chewed in a particular spot.
Just got thinking - I used a 95 starter before too.
L3 tranny case is the same for all these sooooo....
all starters should be about the same.
Old Aug 11, 2009 | 10:38 PM
hmm well i returned the starter and bought a different starter from a different store. same description, 91 civic si. but it was totally different from the other one i got. it was the same as my old one. and it worked and no noise. interesting. lol. thanks for the help though
Old Dec 7, 2011 | 09:48 PM
acmoc's Avatar
I need a picture of your starter please?
Old Sep 17, 2013 | 04:53 PM
furikazashi's Avatar
I would totally like to get a link of the starter you used also. ive got a 89 crx ZC motor and I cant find a starter to fit it either. its 1.6 as well l3 tranny
B16afmaxt
Oct 31, 2009 05:14 PM
prelude182
Jan 9, 2009 09:05 AM
Castanza
Nov 8, 2007 07:55 PM
EG6-SIRII
Jan 8, 2007 07:33 PM
DaMmniTz
13
May 28, 2005 03:17 PM
