What tach-eqipped cluster will fit my eg?
Hey guys, i have tried to search this topic, but i can't find anything on my particular year...
neways, i have a 95 EG sedan, and am curious what cluster would fit so that i have a tachometer. I am currently running a VTECAFC to monitor, and i am sick of looking at it.... i don't know if it makes a difference, but i run a d16y8 (custom turbo setup) so maybe there are some redline issues for the tach i should worry about?
I am sure there are a few different possibilities, but i'd like to hear from anyone who has tried this!!
So far i know for sure anything for a 92-95 sedan, hatch or coupe will fut, i am currently running a 93 Sedan gauge cluster in my car for the same reason. I didn't have a tach. The only issue i was told about was, and anyone correct me if i am wrong, is that the speedo heads might be different, but it only takes a couple mins to swap speedo's out of the old cluster.
and BTW,
I want to use an OEM cluster, not an aftermarket neon green one or something dumb like that.
Would any Acura clusters fit ?
I am using an oem cluster, its out of an auto, so i got the PRND lights in it but they dont work, as for any other clusters, they will fit, but you gotta do some custom work to make them fit your cluster trim correctly. I am unsure about the wiring though, i am pretty sure there was a post somewhere on here about that. I'll see if i can find it again
you can make pretty much any honda/acura cluster fit with some work.
But if you just want straight swap plug N play stick with 92-95 (JDM/USDM) civic clusters.
SiBlueEG6
Sep 4, 2009 07:25 AM
jadugartir
Oct 9, 2006 07:42 PM
msinsky14
12
Mar 1, 2006 07:36 PM
