Dr. Marv's Transmission Hot Rod 09
Dr. Marv's Transmission Hot Rod Build…
Motor..
Dart Block 83mm
CP’s 10:1 Custom Cut Pistons
Manley Rods
LS Crank
GSR Head Ported by Bob’s Machine Shop.
Ferrea Valves 0.5+mm Over Intake/Exhaust. Retainers, Springs, Bronze Guides.
Type R Cams
JG Intake Manifold
Throttle Body 76mm Blox
Aviad 3 Stage Dry Sump/ 9+ Quarts Aviad Oil Can.
GT-45 Turbo 81mm Compressor/1.28housing
Full-Race Twin Scroll Manifold with EGT Ports.
Drive Train..
Liberty Gear Set
Liberty Billet Bell Housing
Tilton Carbon/Carbon Clutch
Tilton Hydraulic Release Bearing
Tilton Master Cylinder
Mark Williams Complete Axel Setup, Spool
G-Force Long Shifter
Arizona Fabrication- Mid Plate
Electronics..
Motec M800
Motec Harness
Aim Sports Digital Dash
T1 M&W Pro 14 CBR Ignition Kit
T1 Cam Trigger Kit
Fuel Setup..
Kinsler Cam Driven Pump
8 Siemens 2200cc Injectors
Primary Fuel Rail Golden Eagle
Secondary Fuel Rail Custom T1 Built Rail -12.
(Fuel M1- Methanol)
Cooling..
Precision Liquid to Air Cooler
Chizzle Performance Water Tank
Custom Small Radiator Setup
Car Chassis..
EG
Franks Customs,
Front & Rear
Fiber Glass Front End, Doors, Hatch, Wing.
Plexiglass all around
Carbon Fiber Dash Board
Traction Bars
Anglia Complete one piece rear end
Strange Rear Suspension
Omni Drags Front Suspension
Omni Front lower Control Arms.
Weld Rims Front/Back With Custom Bead Lockers.
Tire Size Front- 28x10.5x15 Mickey-Thompson
Tire Size Rear- 26x4.5x15 M&H
Dr Marv’s Would Like to give a special thanks to CLM Motor Sports for there Guiding help and support, Also to T1 Race Development for tuning and giving us a hand.
*Some pictures are outdated with ignition setup and few other odds and ends tomorrow I will post up current engine bay pictures.*
Only Data From the track so far was that we completed License Test. Last pass was 9.1 @ 157 under 30psi. Hopefully This week We will have some more data and in the 8’s with out any problems… I will keep you posted….
Motor..
Dart Block 83mm
Manley Rods
LS Crank
Type R Cams
JG Intake Manifold
Drive Train..
Liberty Gear Set
Electronics..
Motec M800
Motec Harness
T1 Cam Trigger Kit
Fuel Setup..
(Fuel M1- Methanol)
Cooling..
Car Chassis..
EG
Franks Customs,
Front & Rear
Traction Bars
And I also wanted to just throw this picture out there to show how close I was to the octagon at UFC 101 this past weekend.!! Best time of my life!
Car looks sick.
