replacing window Regulator on 99 ex.
hey guys my friend needs some info on his 99 ex coupe. his driver side window goes up and down Slowly to the point where he needs to help it back up and down. its the Window regulator right? anyone got a price? also is it hard to replace?
I don't know a price but they aren't that hard to replace.
1.You remove the door panel
2.roll the window half way down
3.remove the two bolts that hold the window
4.Remove the window
5.disconnect the regulator
6.Remove the 4 bolts that hold the regualtor in place.
7.Remove and replace.
Check the local junkyard
4.Remove the window
Replacing the motor is almost the exact same process as replacing the window regulator. Instead of removing the window regulator u just remove the glass then the motor. I'm not quite sure but you might have to remove the window regulator to be able to get to the motor. Somebody confirm this plz...
zroluv32
Oct 5, 2014 08:23 AM
JDMgunmetalCRX
Mar 31, 2009 08:50 AM
