Alternator - Convert a 3 prong plug to a 4 prong plug?
Old Aug 10, 2009 | 04:35 PM
disguise418's Avatar
Default Alternator - Convert a 3 prong plug to a 4 prong plug?
I'm swapping a b18c5 motor (01 uddm) into a 99 Civic HB w/ 99 Civic SIR wiring harness(I think usdm but no knock sensor plug). My alternator is a 01 type r with a 4 prong connector and alternator plug on my wiring harness is a 3 prong plug. So, my plug on the wiring harness doesn't have the green wire. So, I was wondering if it's possible to convert the 3 prong to a 4 prong and if so, how do you do it?
Thanks
Old Aug 11, 2009 | 07:41 AM
Default Re: Alternator - Convert a 3 prong plug to a 4 prong plug?
Newbie here please help
Old Aug 11, 2009 | 04:10 PM
94EG8's Avatar
Seagull Management
Sounds like you have a Canadian SiR harness (all Candian 6th gen civics use a 3 wire alternator plug instead of the USDM 4 wire setup, IIRC its because the Canadian civics don't have an ELD) easiest thing to do in this situation is to reuse the original SiR alternator.
Old Aug 19, 2009 | 08:33 AM
thanks for the help
deguzmanEG
Apr 18, 2010 05:00 PM
chillz03
Mar 12, 2009 08:01 PM
Jaker
Jun 14, 2006 07:22 PM
BlueShadow
Aug 2, 2004 12:36 PM
