All what I whated to do is zoom zoom in my boom boom =(
Old Aug 10, 2009 | 03:08 PM
killercrx91's Avatar
Icon6 All what I whated to do is zoom zoom in my boom boom =(
Yeah well I got an new pair of speaker for my honda. It's an base model so it never came with rear speackers but it does have the wires. Well my problem is that the wires are to short to reach the speaker... So what do I do is there any wire harness out there to made the wires longer?
Old Aug 10, 2009 | 04:07 PM
Default Re: All what I whated to do is zoom zoom in my boom boom =(
Old Aug 10, 2009 | 04:32 PM
jdmwannabee's Avatar
extend them.
Old Aug 10, 2009 | 06:35 PM
Originally Posted by jdmwannabee
extend them.
I know that but HOW?
Old Aug 10, 2009 | 07:16 PM
Demon86RJC's Avatar
Hello
This how I would do it.
What you would need:
Wire (18 or 16 Gauge)
Slide Connectors (Same Gauge As Wire)
Electrical Tape
Wire Cutters
Wire Strippers (Recommended) (You could use the wire cutters. This just makes it easier)
Solder & Solder Iron (Recommended) (Makes a better connection & makes sure the connection wont come apart)
Here is a step by step:
1. Use the wire cutters to cut off the ends of the old wires.
2. Cut the new wire to the size you need. I recommend adding a little extra wire.
3. Use the wire stripper or cutters remove ¼ - ½ inch of the rubber coating from the end of the old wire & both side of the new wires.
4. Connect one end of the new wire with the end of the old wire and twist together.
5. Solder the ends together &/OR use the electrical tape to protect the new wire connections.
6. On the other side of the new wire put the slide connector on and use the wire cutters to crimp the end closed around the wire.
Hope That Helps!
Old Aug 10, 2009 | 07:43 PM
twentyhurtz's Avatar
i'm sorry, but i kinda laughed when i saw this thread... all panic for something very easy, no offense, just saw alot of humor in it.
Old Aug 11, 2009 | 01:04 AM
8520's Avatar
I thought the same thing.
Old Aug 11, 2009 | 03:56 AM
Originally Posted by Demon86RJC
Hello
Electrical Tape
Wire Cutters
Hope That Helps!
Ok hey thanks. I got the everything to do that but I this whated to make shorw before I start to cut up my OEM wires.
Old Aug 11, 2009 | 08:23 AM
nsxxtreme's Avatar
Usually what I always did is found an old set of stock speakers. Cut the connectors off of them then made extensions. This way no hacking to the OEM wirring required.
Old Aug 11, 2009 | 08:25 AM
92teginsc's Avatar
do you speak english?
Old Aug 12, 2009 | 06:21 PM
98civdx's Avatar
Master Detailer
there just wires lol
Old Aug 13, 2009 | 09:01 AM
Ok I whated to do an Update on the hole speaker problem i'm having. Now I fixxed the wires and they are longer now and can reach the speaker with no problem. But it still doesn't work? But if I hit an bump on the street it would work for a far sec but that's it??? So what's the problem?
Old Aug 13, 2009 | 03:39 PM
98civdx's Avatar
Master Detailer
connections are bad, check the wires on the deck.
Old Aug 14, 2009 | 08:51 AM
XstreamRocker's Avatar
Did you solder the wires? because if you didn't then the connections probably came apart when you put the speaker in place.
Old Aug 14, 2009 | 12:54 PM
EvenStar's Avatar
Lol.
Old Aug 14, 2009 | 06:22 PM
Yes I do to your mom
Old Aug 14, 2009 | 06:32 PM
dohcvtak's Avatar
what! lol dang u gonna let him say that about your moms?
Wazup
Apr 18, 2011 04:04 PM
messeduprex
Dec 16, 2008 07:13 PM
Tippyman
Audio / Security / Video
23
Nov 28, 2008 03:10 PM
D16Z6racing
Mar 21, 2007 05:56 AM
mrlegoman
Feb 3, 2003 04:15 PM
