help swaping out my LS motor
Old Aug 10, 2009 | 03:08 PM
RIPED AIMAL's Avatar
Default help swaping out my LS motor
just wondering i got 2000 b18c1 head, all itr head internals port and polishing, b18c1 block going to completely build it, gsr ecu, 95 gsr tranny non lsd, waiting for itr lsd, itr final drive, and itr 2nd gear, have itr water pump, and oil pump, jdm t/3 t/4 50 a/r turbo, is there any thing else i need to swap before i transplant this motor build? will all the ls hoses, a/c distributor etc be ok??
please help thanks so much,
Old Aug 10, 2009 | 04:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: help swaping out my LS motor
I thought you were doing LS/VTEC turbo
Old Aug 10, 2009 | 05:22 PM
Circusraven's Avatar
I'm confused now Patrick
Old Aug 10, 2009 | 05:24 PM
Community Builder
https://honda-tech.com/forums/acura-integra-6/my-first-ls-vtec-turbo-build-need-some-help-2621341/
Old Aug 10, 2009 | 06:32 PM
Yes Yes, but he needs to make up his mind
Old Aug 10, 2009 | 06:46 PM
hey patrick, i cant use my smog guy no more to pass me so im going itr fully built turbo got just about everything...wow your being nice for once, i cant believe it....
please dont report me or delete my thread....thanks dude, i mean Mr. 94 gsr
Old Aug 15, 2009 | 04:49 PM
good news my year 2000 b18c1 head should be done by tuesday, ported, polished complete super tech valve train, 3 angle valve job, with itr camshafts and cam gears,
my b18c1 short block is almost complete as well by tuesday 81mm LS crank, pr3 pistons, arp rod bolts shotpeened resized assembled,
will post up pics next week when i recieve them, going to order new oem gsr wire harness, 600.00 bucks, got gsr intake mani, need axles, mounts, and itr tranny and usdm front seats,
1 question i have is with this build what type of heads will fit the job and give me the best performance n/a for a while.,....
thanks
Old Aug 16, 2009 | 06:53 PM
tuesday i shuold have my built block is this a good build for a n/a motor??
pr3 pistons arp rod bolts LS rod shotpeened and resized, LS crank new bearings piston rings oil pump all assembled
Old Aug 18, 2009 | 01:55 PM
Hey guys i ready to swap out my LS with a fully built b18c1
just need to know if im missing anything, i have the fully built head, block, tranny, gsr ecu, gsr wireharness big ups to john in florida for that, motor mounts, axles, also was wondering what kind of timming belt to use for the set up and can i use my LS hoses or do i need to replace them? Thank you for the help
oh btw also have gsr oil and water pump
MShonda
Mar 6, 2012 07:02 PM
EF_LSVtec
Apr 25, 2006 01:18 PM
s2kkid
Jul 2, 2005 06:53 AM
Fuzion
Aug 12, 2003 04:33 PM
speedevo
Aug 22, 2002 11:07 PM
