Transmission issue, need help quickly
Old Aug 10, 2009 | 07:44 AM
B18c1vicrx's Avatar
Default Transmission issue, need help quickly
alright, so i was driving my car and it jolted suddenly so i put it into neatral and coasted off, after that it was hard to put into gears and even when the shift **** is in neutral is stalls when i let off the clutch so i think my tranny is stuck in a gear regardless of where i put my shift ****. any help please, its a ys1 if that helps...also before this happened downshifting to 3rd was a problem from 4th, id have to put the shifter into 2nd then it would go into 3rd easy. any ideas?
Old Aug 10, 2009 | 10:05 AM
Sl1ck09's Avatar
Default Re: Transmission issue, need help quickly
1st: make sure the ur clutch linkage is connected to the tranny. a bolt may have fallen off.
2nd: check to see if ur adjustment is correct and that the release fork isnt stuck.
hope this helps
make sure ur adjustment isnt over tighten
Hatchbacksonly
Dec 2, 2012 04:20 PM
Demonis
Honda Civic (2006 - 2015)
Mar 24, 2007 09:37 AM
sparknblaze
Oct 31, 2006 06:38 AM
89civichatchback
13
Jul 9, 2003 11:23 AM
boomslang
Nov 18, 2001 12:00 AM
