hondata vs crome rom
Old Aug 10, 2009 | 06:51 AM
crxb16a90's Avatar
Default hondata vs crome rom
just kinda wonder. so crome u can burn map to the rom run it on your ecu, right? if u need data logging stuff like that u have get more hardware on there. now if u can use hondata rom editor and burn the map creat by it on the same rom, will it run the same way without the hardware?? like buying a hondata s100/300? those hardware for more function right? or hondata creat map depend on the hondata hardware??
Old Aug 10, 2009 | 07:22 AM
98vtec's Avatar
moderator emeritus
Default Re: hondata vs crome rom
im having a hard time understanding what you are asking.
If you are asking if you can copy the map values from hondata to crome...you can, but it will not run the same.
go with the better software. Less headache.
Old Aug 10, 2009 | 08:13 AM
crxb16a90's Avatar
i found the answer to it. hondata bin only work with the interface, guess their way to make u get a hondata. thx for help
Colorado_teggy
Engine Management and Tuning
Dec 20, 2014 03:11 AM
bcp0715
Acura TSX
Apr 13, 2013 05:14 AM
