H22A OBD1 timing belt procedure
Old Aug 10, 2009 | 04:11 AM
JDM_Certified's Avatar
Default H22A OBD1 timing belt procedure
i saw this is preludezone.com, is it necessary to do this when u allready top dead the whole motor?
8. Make sure the crankshaft is positioned with the No. 1 piston at TDC.
9. Align the groove on the front balancer shaft pulley with the pointer on the oil pump housing as shown.
10.Align the rear balancer shaft pulley by using a 6x100mm bolt as a alignment tool. Insert the bolt into the maintenacne hold about 3/4 the length of the bolt.
11. Loosen the adjusting nut and verify that the timing balancer belt adjuster moves freely
12. Install the timing balancer belt. Remove the 6x100mm bolt from the rear balancer shaft.
13. Turn the crankshaft pulley about one turn, then tighten the adjusting nut to the specified tq.
Both belt adjusters are spring loaded to properly tension the eblts. Do not add any extrea pressure to the pulleys or tensioners while adjusting.
Old Aug 10, 2009 | 08:21 AM
hondamark35's Avatar
Default Re: H22A OBD1 timing belt procedure
yeah, the pulley can be lined up with the mark on the oil pump but not truely be in time. it's because of the gearing behind the housing that makes the rear shaft spin clockwise (opposite crankshaft rotation). using this method is good insurance that the shaft is timed properly, although it can just as well be done without the long bolt.
JDM_Certified
Oct 7, 2009 04:25 PM
ohdannyboy111
Nov 19, 2007 06:41 PM
hon
Sep 21, 2004 03:54 AM
Shady Hills
Jul 24, 2004 09:40 PM
Mover
Jul 30, 2002 09:35 AM
