Suspension & Brakes Theory, alignment, spring rates....
4x100 DC2R brake upgrade for EK
Old Aug 10, 2009 | 01:52 AM
jimlaH's Avatar
Default 4x100 DC2R brake upgrade for EK
Okay now i want to upgrade my brakes to dc2r spec but keep it 4x100.
I have found that for the front i need ek4/em1 knuckles, dc2r calipers, rotors redrilled to 4x100 and 3.2mm (some1 pelase confirm) shaved off the caliper mounting bracket.
But for the rear, i currently have an EG6 rear brake setup. Is it possible to upgrade to a dc2r caliper with redrilled 4x100 rotor and mount it by modifying the mounting bracket or something similar like on the front? And ofcourse have the e-brake still function.
Old Aug 10, 2009 | 05:32 AM
phunhaus's Avatar
Default Re: 4x100 DC2R brake upgrade for EK
For the rear you can look into the 4lug EP upgrade.
For the front, EM1/EX/DC2 are the same size. There are plenty of factory upgrades listed in this thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-put-x-brakes-your-96-00-ek-civic-revised-upgrade-chart-1513752/
Old Aug 10, 2009 | 09:24 PM
jimlaH's Avatar
yeah got the fronts sorted. i wasnt too sure if my setup would be any different coz its from an eg6 but i guess not. thanks 4 the reply
Old Aug 11, 2009 | 09:46 AM
AdicUar's Avatar
go to www.fastbrakes.com they have the caliper brackets and larger diameter rotors type-R size but 4x100 you are looking for. front and rear kits available. you just retain your calipers or you can upgrade those as well with type-r, legend 2pots or NSX units
Jon777
Suspension & Brakes
May 26, 2011 02:00 PM
iNERtIA
Feb 4, 2006 01:17 PM
Ashnice
Jun 30, 2004 02:59 PM
menkio
Apr 26, 2004 05:05 PM
speedevo
Sep 30, 2002 07:53 AM
