89 crx with b18a1 startng problems
Old Aug 10, 2009 | 01:26 AM
crazyboy's Avatar
Default 89 crx with b18a1 startng problems
i just recently purchased an 89 crx si with a 91 ls motor. my problem is when i turn the key i hear a click from the starter and it wont start. it will start after turning the key a bunch of times. but tonight it stopped working completely. i replaced the starter with an extra and its still just clicking. what can i do?
Old Aug 10, 2009 | 04:53 AM
dephtone's Avatar
Default Re: 89 crx with b18a1 startng problems
Take the starter and have it checked, it sounds like either the battery might be shot or the solenoid isn't kicking out the gear to turn the flywheel. I would make sure that your battery terminals aren't loose or anything. Does it make a sound like a dead battery would like a cliiiiiiiiiick?
My car would click and I found out the battery terminals just needed some good old cleaning off, been fine ever since.
Old Aug 10, 2009 | 10:54 AM
crazyboy's Avatar
well the battery is 2 months old, and i replaced the starter with an extra one last nights. ill replace my terminals today, any other suggestions?
Old Aug 10, 2009 | 11:26 AM
bradennicely's Avatar
check all the connections to the battery, did you relocate it?
Old Aug 10, 2009 | 11:54 AM
boostedEF91's Avatar
sounds like a bad connection or ground.. maybe a relay.. what did you try so far.?
Old Aug 10, 2009 | 12:03 PM
crazyboy's Avatar
i checked the battery connections. they appear good. i tested the wire on the starter from the ignition switch and it gets power when i turn the key to crank. i took a jumper cable and hooked it to the bolt that mounts the starter and put the other end to the shock tower. the battery is relocated but the previous owner did it. any ideas guys?
Old Aug 10, 2009 | 01:36 PM
crazyboy's Avatar
boostedef91: what relay(s) should i check? and where are they located? this is my first crx ive owned integras all my life
Old Aug 10, 2009 | 02:26 PM
iheartteal's Avatar
get both the starters checked, how do you know the extra one have isnt bad as well.
Old Aug 10, 2009 | 02:29 PM
beansandrice's Avatar
Try to turn the engine by hand with a ratchet. Hopefully it turns if not you got a locked up engine.
Old Aug 10, 2009 | 03:28 PM
EF-Devotion's Avatar
have you try push starting the car to see if it starts. if so your starters might be gone. have both your starters check out at a auto parts store like autoazone.
Old Aug 10, 2009 | 04:36 PM
crazyboy's Avatar
i had them checked, one was good. i put it in and it started up. i put the intake and strut bar one and tried again and still the same problem. the starter just clicks.
Old Aug 10, 2009 | 06:14 PM
xthekidx's Avatar
have you checked all your grounds? also where did they ground out the battery when they relocated it?
Old Aug 10, 2009 | 08:54 PM
crazyboy's Avatar
i added 3 grounds from tranny to chassis and 2 off the battery. the grounded it somewhere behind the back trunk panel. i just had my battery tested and it was good. i changed the terminals because the old ones were beat to hell. im out of ideas
Old Aug 11, 2009 | 07:06 AM
Hatchguy91's Avatar
It still sounds like a bad starter. The solenoids on them can fail or they can just have a dead spot. The battery could also still be a culprit. How did you have it tested? A battery can still read 12 volts and be bad. If the cells are shot in the battery it could still have full voltage but have almost no amperage. It would be enough to run accessories in the car but when the starter goes to draw most of the amps it would just fail. Without being able to run the tests on it I can't really give you a solid answer. I would imagine there is a starter relay but with your setup I don't know for sure. That could also cause an issue.
Old Aug 11, 2009 | 07:42 AM
crazyboy's Avatar
ok so the battery should be good. its fairly new. i had it tested at at autozone. he said it tested at 13 volts. the wierd thing is that when i jump started my car with someone else's it started right up. could this be a ground issue or can it still be the starter?
Old Aug 11, 2009 | 07:58 AM
Hatchguy91's Avatar
So it started with someone else's power supply then? If that is the case I would definately focus on the battery more. Like I said the voltage can read good but the battery still be bad. Lets face it, Autozone is not known for being the best place to diagnose a car. I can't tell you how many times people would come into the shop and say Autozone told them what was wrong with their car and it be completely incorrect. Just to be sure I would try and jump it again with someone elses car. If it works then shut it off and try it several more times. If it starts every time then its probably not the starter. It is possible to have a faulty newer battery. I have installed brand new batteries in customer cars before and they not work right.
Old Aug 11, 2009 | 08:29 AM
crazyboy's Avatar
ok well ill bring in my battery and have it exchanged because it has a 3 year warranty. if that doesnt solve the problem ill let you know. thanx
Old Aug 11, 2009 | 12:09 PM
Channooo's Avatar
I had the same problem. I changed the battery and it was fixed. Maybe it might be something else?
Old Aug 11, 2009 | 02:43 PM
crazyboy's Avatar
i just put in a new battery and it was still doing the same thing. so off to get a brand new starter and see if that works. keeping my fingers crossed i have 450 wrapped up in this car just today
Old Aug 11, 2009 | 02:54 PM
let us know how it goes.
Old Aug 11, 2009 | 04:44 PM
crazyboy's Avatar
ok so i got a new battery and a new starter. i put the new starter on and it started. i turned it of and back on it started again. i tried it again and it clicked again like before. then i did it again and it stopped clicking. im out of ideas
Old Aug 11, 2009 | 05:09 PM
are the contact parts on the chassis full metal or is there paint on where ground is at. clean the ground part on the chassis with a wire brush. make the ground is clean and has full contact. check your power ire for cuts and short.
Old Aug 11, 2009 | 05:15 PM
liquidrider's Avatar
Check all of your grounds again, try grounding your battery somewhere else.
If that doesn't help: Replace the cable running from your battery to the starter, it probably is toasted. The one I used to put my battery in the hatch was out of a Caddilac CTS, they keep their battery under the rear seat. It was about 2-3 feet longer than I needed. Go down to a wrecker they will probably sell you one for $10 and it has the post terminal on it already with a ring terminal on the other end.
Old Aug 11, 2009 | 11:06 PM
enigma2446's Avatar
is the click coming from under the hood or inside the car...if its inside the car then it might be ur main relay i had this problem in my 91 integra...switched out and walla it starts
Old Aug 12, 2009 | 02:46 AM
crazyboy's Avatar
ok so i took off the crounds, cleaned them and reinstalled. it took all day. that still didnt help and it doesnt even click anymore. it started like 10 times in a row. i left it sit for a while and it wont start again. idk whats up with it sounds like a relay or something
