Best header B16 road clearance
Old Aug 10, 2009 | 12:03 AM
Super79Dave's Avatar
Default Best header B16 road clearance
So i've dented my header. i repaired it but i'm curious which header is out there on the market with the best road clearance.
Was hoping for 4-1 that would tuck up into the pan a little more.
Old Aug 10, 2009 | 12:45 AM
BiG ChOr!Zo's Avatar
Default Re: Best header B16 road clearance
how about lifting up your car a bit
Old Aug 10, 2009 | 04:55 AM
dephtone's Avatar
What kind of header do you have? Unfortunatly that is one downfall about a 4-1 header is it does hang really low, if you are worried about clearence you will probably have to look into a 4-2-1 as this doesn't need as much room because you are only tucking 2 pipes instead of all 4.
Old Aug 11, 2009 | 06:25 PM
The car is actually a road race car and our current track is very bumpy if you have an of any where presto dented header.
i know you'll say stay on the track. Well sometime easier said than done. Ie water on the track in the braking zone.
Anyway the current header i have is a megan racing header, What i would really like to have is a header that fit more closely to the block and up further into the pan.
if they're isn't anything avail i will probably just cut up my current and modify.
???? i have an upper part of a JASMA header does anyone have a pic of this header and clearance. I may use it and fab my own lower pipe.
Old Aug 11, 2009 | 10:17 PM
michael O's Avatar
I can't really help you. But whatever you do don't use a JG 4-2-1. From the front it looks like my car has some fat *** nuts dragging on the ground.
Old Aug 12, 2009 | 03:38 PM
BUMP
Old Aug 12, 2009 | 04:03 PM
Radim's Avatar
You can try using one of those skid plates
I'm not quite sure which header has the best clearance but if it's just a road race car and not being used on the streets i'd say just get a side-exit header.
Old Aug 12, 2009 | 04:34 PM
c.dub's Avatar
I cannot remember who the seller is, but there are some companies on H-T here who make a replica of the Hytech 4-1 header. Some of them are redesigned slightly to allow better clearance. Saw some pics and they tuck in pretty nicely by the oil pan. Hopefully someone can chime in as to who the company is on here who makes it.
Old Aug 12, 2009 | 05:46 PM
redflaredcrx90's Avatar
have a skid plate made
Old Aug 12, 2009 | 05:55 PM
ALLxMOTOR EG's Avatar
Vietnamese!
I lol'd.
Old Aug 12, 2009 | 06:55 PM
beansandrice's Avatar
LOL!! I almost sht myself
newarkR
Jan 25, 2004 05:32 PM
ImporttRacerr555
Nov 25, 2003 02:13 PM
7rrivera7
Jan 17, 2003 09:55 AM
