96 gsr what to do with it
Old Aug 9, 2009 | 07:40 PM
beesting00si's Avatar
Default 96 gsr what to do with it
i have a 96 GSR with the JDM ITR front end conversion and a jspec b18c, i want to get some good power out of it, but i dont really have the fund to turbo right now. but i could. what should i do with it performance wise, im open to any ideas. thankss
Old Aug 9, 2009 | 08:29 PM
dapek's Avatar
Default Re: 96 gsr what to do with it
If you don't have the funds for boost then you definately will not have the funds for a good NA setup for any real power.
IMO you should save your money for boost if power is what you want.
Old Aug 9, 2009 | 11:25 PM
Ruben19's Avatar
leave as it is.
if money is a major issue .
M.I.A.M.I
Old Aug 10, 2009 | 05:01 AM
Boxer911's Avatar
Enjoy the b18c for what it is.
Old Aug 10, 2009 | 01:11 PM
East's Avatar
intake mani!
Old Aug 10, 2009 | 05:32 PM
redDAinteg's Avatar
+1
If you want something fast for the money, might as well turbocharge it. You can peice together a good kit for around $1500-2000. Sometimes I also see JRSC superchargers used for about 1000-1500 which would add good power with a tune.
If you want to go with a mild all-motor you can figure skunk2 cams for about $500-700, camgears would be about $100-200, plus springs and retainers would be another 200-300, and this is assuming you have intake,header and exhaust already. A good tune should be $500 and under depending where. which would be equal to $1200-2000 and you can look forward to 210whp and under.
That turbo for the same price will give you over 280whp easy with a b18c.
Old Aug 10, 2009 | 05:48 PM
Stevo-DA's Avatar
i would enjoy the GSR for awhile and plan everything out for a mild NA or Turbo build i would go with I/H/E and some head work 200whp is fun to drive around
Old Aug 10, 2009 | 05:58 PM
OrangeTeggy's Avatar
Just start out with the basics
Steeve_Civic
Oct 8, 2013 05:44 PM
batto24GSR
Aug 25, 2013 04:51 PM
ososlowracin
Sep 26, 2007 08:37 PM
cool
Mar 25, 2003 04:28 PM
