Suspension & Brakes Theory, alignment, spring rates....
Rear Swaybar question
Old Aug 9, 2009 | 07:27 PM
Wakes4Fun's Avatar
Default Rear Swaybar question
Just bought a 94 Civic DX hatch and I'm wanting to throw my ST swaybar on it but it seems there aren't threads were the brackets mount to the frame?? My 93 Del Sol has them but not this car. Is there another way to mount it?
Old Aug 9, 2009 | 07:40 PM
ej1love's Avatar
Default Re: Rear Swaybar question
yea nuts with bolts son, this is stupid my ej1 didint have them for the rear either. poopoo...
Old Aug 10, 2009 | 01:16 AM
string's Avatar
Drill.
Be realistic about how you mount it. The mounts experience a lot of force so think about where the force is going and if it's just going to rip them out or not. Adding a D-bracket to a thin subframe doesn't sound like a very good idea to me.
Old Aug 10, 2009 | 07:19 PM
kristo's Avatar
Loved
You have to drill the holes (eg check ASR online 'Instructions'). Contrary to EKs only EGs with rear swaybar have the holes drilled.
Mounting a swaybar on the OEM subframe is NP when you stick to <=16mm (= OEM/EG6 sway size). Be sure to use/fabricate some kind of backing plate (standard on EG6).
Personally I would get either the OEM EG6 16mm or an ASR brace/ITR 23mm combo.
Be sure in any case to mount an EG6 sway up front (if diff from your ori).
wraprail
11
Apr 24, 2016 05:55 PM
Tim2179
Nov 1, 2010 09:57 AM
iwannarace
Aug 29, 2010 11:46 PM
Forrest Gump 9
Aug 4, 2004 02:43 PM
DaiJekBok
May 23, 2004 03:49 PM
