What is up with my car?!
Old Aug 25, 2002 | 03:31 AM
blufke's Avatar
Default What is up with my car?!
Alright, here it is:
so i will be driving around fine for a while, and then all of a sudden the car will start to studder, it wont accelerate(just bog at current speed) unless it is at full throttle. what is going on? i am throwing an o2 cel and a VSS cel(vss broken for now), but why would it be fine most of the time, and then start to do that? also, if i turn the car off then on it may not come back for a long time, start within a minute, or not happen at all. whats the dealio yo?!
its buggin the hell out of me, and an o2 sensor from autozone is expensive as hell.
Old Aug 25, 2002 | 09:42 AM
sivik2nr's Avatar
Default Re: What is up with my car?! (blufke)
O2's from like autozone and carquest and stuff are like 60 bucks....
If you havent changed it in a while , then I suggest you change it anyway,, especially if you get a cel.....
Old Aug 25, 2002 | 11:45 AM
blufke's Avatar
Default Re: What is up with my car?! (sivik2nr)
autozone
universal o2= 69.99
94 ls OEM spec o2 = 149.99
any other options?
Old Aug 25, 2002 | 02:03 PM
blufke's Avatar
ne1?
Old Aug 25, 2002 | 02:22 PM
Stryker908's Avatar
Sounds like what happend to my car b4 it died .... I had an automatic Neon it used to slow down unless i was at full throtle then it would jump back up ... or it would get stuck in 2nd gear and not shift ... it would stall at lights ..... I ended up taking it to dodge (under warente ) the told me it was 5600 woth of damage ..I only owed 3000 on it so They gave me the market value of the car ... and i bought a honda ... Happy ever sence ... Hope your not that bad but get it checked now !!!
Old Aug 25, 2002 | 02:38 PM
blufke's Avatar
Default Re: What is up with my car?! (JDM_SIR_II)
well mine doesnt stall, or get stuck in gear but thanks, o2 solution? anyone else?
Old Aug 25, 2002 | 02:49 PM
Jstue's Avatar
shitty injectors??.. what kinda gas u run?
Old Aug 25, 2002 | 03:20 PM
blufke's Avatar
Default Re: What is up with my car?! (grow2be)
91. but how could it be the injectors? anyone else?
Old Aug 26, 2002 | 02:46 PM
kongzilla's Avatar
check your spark plugs and wires.
Old Aug 26, 2002 | 02:49 PM
GetawayInMoscow's Avatar
Default Re: What is up with my car?! (kongzilla)
Fuel Pump/Fuel filter?
Old Aug 26, 2002 | 03:15 PM
vtechatch's Avatar
Default Re: What is up with my car?! (GetawayinMoscow)
If you dont have the cash just take out the O2 sensor and clean it with some Contact or Brake cleaner and see if there is a change.If there is,get a new O2 sensor cause that will last about a week before it starts again.
Dan
Old Aug 26, 2002 | 11:56 PM
blufke's Avatar
Default Re: What is up with my car?! (vtechatch)
alright thanks. changed plugs,plug wires,fuel filter during swap. but i dont know why it would happen intermittently. its happening every time i drive now. ill try that cleaning idea. thanks. any more advice? i still have the o2 from my vx motor, possibility there?
[Modified by blufke, 8:57 AM 8/27/2002]
Old Aug 27, 2002 | 12:01 AM
ZeroEric's Avatar
that dont sound good if it gets worse... I doubt its your o2 sensor but it should be replaced anyway... Take it to autozone or a reliable mechanic and have them check it out, that CANT be good man... and the o2 sensor prices. Better that $200+ from the dealer, so take your pick...
Old Aug 27, 2002 | 01:12 AM
blufke's Avatar
Default Re: What is up with my car?! (iviZeRoCooLivi)
but i mean, if a car drives fine and nothing seems wrong, then it starts to happen, what is up?
Old Aug 27, 2002 | 05:01 AM
jetli6969's Avatar
New User
i would like to know also, my car is doing the same, and im running rich as hell.. new o2 sensor
Old Aug 27, 2002 | 05:23 AM
Civic1992DX's Avatar
Default Re: What is up with my car?! (jetli6969)
Good place to buy O2 sensors:
http://oxygensensors.com/
It cost me $54 shipped for japanese-made O2 for my B18B1.
Yuri K
Old Aug 27, 2002 | 11:10 AM
blufke's Avatar
Default Re: What is up with my car?! (Civic1992DX)
Yuri K
that is a rather helpful link. saves me 15 bux. w00t!
Old Aug 27, 2002 | 11:00 PM
blufke's Avatar
alright, cleaned o2 w/brake cleaner. got better for a while but not long. could it still be the o2. its not nearly as bad as it was before the spray, but still bad. recommendations? should i just get the new o2?
Old Aug 27, 2002 | 11:10 PM
ZeroEric's Avatar
go get a new o2, if it keeps it up have it checked...
Old Sep 4, 2002 | 04:00 PM
blufke's Avatar
alright, i got my new o2, and everything seemed fine for a while(about 20 min.) and then it started to studder again, and it still goes away at full throttle. WHAT SHOULD I DO?! what should i have checked? ive done fuel filter,plugs,wires,o2 sensor. could it be the pump? what could it be!!! arrgghhh. thanks.
Old Sep 7, 2002 | 01:02 PM
dinosa21's Avatar
sounds like you should hit it with a hammer
Old Sep 10, 2002 | 01:45 PM
blufke's Avatar
Default Re: What is up with my car?! (dinosa21)
thanks!! thats helpful. you *****!!!!(my car can beat yours. )
oh, i cant go with you to best buy, because i promised id go there with my girlfriend first.
Old Sep 10, 2002 | 02:35 PM
IDriveHonda's Avatar
2 things that I can think of, I didn't see anyone else post them but I read fast so I apologize if somebody else said this but, I would check your rotor (ignition) and make sure that the set screw is tight, because if it backs out it can produce the same results. It could also possibly be the cat getting clogged, this will cause a dramatic power loss. Hope this helps.
Old Sep 10, 2002 | 06:19 PM
blufke's Avatar
Default Re: What is up with my car?! (IDriveHonda)
ran through the helms test which points to not an o2 problem but i got a code 43 doing their test. fuel system problem is what its pointing to. changing my pump to a teg pump in the next hour.
Old Sep 10, 2002 | 08:25 PM
lilxvtecxpwr's Avatar
hey, i think im having the same problems as you... when it studders, does it suddenly jerk hard? well mine does that...i dont know whats wrong with it...it does it every now and then but it does it everyday. some ppl told me that it might be my ignition coil, i dont know yet, i'll have to check into that later.
