PARTING OUT 2000 Civic SI. great prices, pickup ONLY! prices listed AFTERMARKET TOO!
Old Aug 9, 2009 | 12:26 PM
maxum17ft's Avatar
Default PARTING OUT 2000 Civic SI. great prices, pickup ONLY! prices listed AFTERMARKET TOO!
EVERYTHING IN PICTURES IS ALSO FOR SALE!!! parts listed is what is in my garage, make an offer on anything you see in the pics. mint complete 2000 civic si milano red doors, black trunk, milano red sideskirts, 97 back back bumper, 00 front bumper, airbags, 2000 leather si steering wheel, mint 2000 dash, basically complete shell minus drivetrain. not selling shell though, quarter panel is CRUSHED. also have a spare passenger side quarter panel for sale because i was going to fix the car but i dont have the time.
$220- COMPLETE si rear disc brake conversion off of the red car seen below. 86k miles, minty, only sitting since i wrecked it in july. coming with EVERYTHING including proportioning valve. only thing im keeping are the pads for my other si.
$100-P2T 2000 civic si ecu, perfect.
$150ea.-mint complete 2000 civic si milano red doors(SALE PENDING! both)
$50-black trunk
$50-milano red sideskirts
$25-97 back back bumper
$30-00 front bumper
$175-2000 leather si steering wheel with airbag
$100-2000 civic si dash
$15-40ea-interior parts, ask about them.
$60-black 96-00 complete quarter panel
si/gsr b series parts:
$170-RC Engineering 550cc saturated injectors, used for 12k in my SI, upgraded to 680's for 21psi, theyre mint
$155-em1 civic si seats out of my car. mint except for one tiny tear in the drivers bottom seat that u dont even notice.
$60-t3/t04E turbo. only has 5k miles and is mint but the compressor sucked up a piece of plastic from the air filter and ruined the cold side fins. just needs the compressor fins. no play.
$60-96-00 full passenger side quarter panel
$100-b16a2 '00 civic si distributer
$40-jdm gsr vtec solenoid setup
$80-usdm b16a2 '00 civic si throttle body with perfect sensors
$50-stock b16a2 cams
$20-oem spark plug cover b16 or gsr
$15-oem gsr/b16a water pump, low miles
$40ea.-(2) jdm gsr/b16a oil pumps, no ckf sensor since jdm, need chipped ecu
-(3) bare jdm b16a blocks, $85- 1 needs honing, comes with crank, $65-one needs boring, the last is good for core fee-$50
$25-'00 civic si lower drivers side ac bracket mount
$20ea.-(2)obd1 upper driver side mounts b-series(3 bolt mounts into block)
$30-ARP rod bolts for d-series, 8mm ones, brand new
-(3) b16a2 timing belts, all under 15k miles, $10 ea.
$15ea-drivers side '00 civic si tail lights (2) trunk one body
$15ea-random obd1 b-series mounts
$20ea-(2)gsr/b16 factory oil catch can setups
$20-(2) gsr crank pulleys with key and bolt.
$25-(2) oem tstat housings with water pipes
$50-b16 crank, mint
$40-b16 crank, one rod spun, still usable if repolished. did require largest bearing, now once polished will just step down a bearing color or two, ask for more info.
$10ea- jdm gsr oil filter water cooled housings(factory oil coolers)
$100-obd1 vtec distributer not sure if b16 or d16
$100-JDM high compression b16a pistons on b16 rods
$30-stock gsr fuel injectors, 240cc obd2
$40-GSR/B16 halfshaft
$40-stock b16 headers with downpipe
$30-stock gsr header
$40-stock 2000 civic si cruise control unit with acc's
$55-stock gsr butterfly secondary controller obd2
$15-stock 1.7 bar map sensor for obd2 bseries
$50-oem 2000 civic si front bumper, holes cut out for fogs, in primer
$40-6000 kelvin h4 hid kit make offer, has cracked bases but still works flawlessly!
$35-stock b16a2 fuel injectors obd1
$50-exedy stage one clutch kit for B-series, used, will need new clutch disk soon but the rest of it is great, was used in my 400whp si and couldnt handle the power. replacement disks are very cheap, its well worth 50 bucks for the pressure plate.
$35ea-(3) knock sensors for b-series
$30ea-(2) oil pressure sensors
random other sensors available, ask...
$5-factory gsr oil filler cap
$100-'98 civic ex power steering rack complete, same as '00 civic si.
a list of other stuff i need to sell:
$50-nextel i880 bad screen, its upside down
$40-nextel i710 mint
$60-nextel i850 mint in box
$40ea-(2)hoosier slicks- 23x9.5x15 used for 3 passes, 85%
$25ea-18x8" rims no tires only have 2
dsm parts:
$45-brand new RRM CAS harness to convert 7 bolt to 6 bolt. retails for $80
$75-real mitsubishi evo 3 big 16g with o2 housing. ported and comes with ss oil feed and coolant fittings.BLOWN
$8ea-interior plastic pieces, grey in color, door, (3)hatch cover, rear pieces
$50-stock 4g63 cams
$20ea-dsm valve covers.
$25-95 awd turbo cruise control unit
$100-fwd turbo act steel streetlight flywheel, used for 200 miles
$10-2g wiper arms
$30-stock dsm side mount intercooler
lancer parts:
$50-evo 7 abs plastic wing
$40-evo 7 extreme side skirts(fiberglass)
shoot me an email if interested.
Last edited by maxum17ft; Aug 25, 2009 at 07:24 PM. Reason: sold things, updated list!
Old Aug 10, 2009 | 08:02 AM
maxum17ft's Avatar
Default Re: PARTING OUT 2000 Civic SI. great prices, pickup ONLY! prices listed AFTERMARKET
bumppp
Old Aug 10, 2009 | 10:17 AM
psi2high's Avatar
Do you have the intake air temp sensor?
Old Aug 10, 2009 | 03:46 PM
etexwagon's Avatar
hey man do you have the oem fog light harness
Old Aug 10, 2009 | 06:21 PM
Atrain89's Avatar
pm sent
Old Aug 11, 2009 | 08:47 AM
maxum17ft's Avatar
pms replied!
Edit: i do have an intake air temp sensor for a 2000 si. its the one that goes into the intake tube not the one that bolts on the manifold. let me know if u still need it!
Old Aug 14, 2009 | 01:43 PM
maxum17ft's Avatar
bump, replied to pm's and sold some parts!
Old Aug 19, 2009 | 10:58 AM
maxum17ft's Avatar
bump!
Old Aug 20, 2009 | 08:05 AM
maxum17ft's Avatar
bump, everything in the pics is for sale! even the tv...
Old Aug 21, 2009 | 08:01 AM
maxum17ft's Avatar
bump
Old Aug 21, 2009 | 11:08 AM
Ej Girl's Avatar
still have the b16 headers with downpipe?
Old Aug 21, 2009 | 02:42 PM
simike's Avatar
PM'ed
Old Aug 21, 2009 | 03:18 PM
EM1 Resto's Avatar
Would you ship the fan assembly if you have it. PM me if you would.
BUMP!
Old Aug 21, 2009 | 06:58 PM
99ekexsi's Avatar
how far away is hazelton from the zip code 17331 and what is wrong with the cf hood?
Old Aug 21, 2009 | 09:21 PM
WanAsPOON's Avatar
BUMP WANT HOOD ASAP !!! PM SENT !!
Old Aug 22, 2009 | 12:57 AM
Arthas's Avatar
Your list is hard to read!!
separate it as interior,exterior, engine, etc etc etc.
Still got the front LCAs? PM me a price!
Old Aug 22, 2009 | 01:38 AM
714jesterek's Avatar
New User
What conditiong is the cf hood in?? And you you still have the head rest??
Old Aug 22, 2009 | 05:30 AM
phazedd's Avatar
pmd
Old Aug 22, 2009 | 08:11 AM
simike's Avatar
Pm returned.
Thanks! Mike
Old Aug 22, 2009 | 09:06 AM
Mag00n's Avatar
im looking for a milano red front lip, and upper manifold heatshield
Old Aug 24, 2009 | 09:04 AM
maxum17ft's Avatar
bump, pm's replied. if i didnt pm then it means i dont have it or its gone!
pete
Old Aug 24, 2009 | 01:40 PM
WanAsPOON's Avatar
bump waiting on call......
Old Aug 24, 2009 | 03:00 PM
dohcdelsol's Avatar
interested in the rc550's. u know if they'll work for n obd1 dseries build?
Old Aug 25, 2009 | 08:37 AM
maxum17ft's Avatar
bump, pm's replied!
Old Aug 25, 2009 | 07:20 PM
ithrowpoop's Avatar
pmed
