Front Speakers Only Work With High Volume
Old Aug 9, 2009 | 12:16 PM
ware's Avatar
Default Front Speakers Only Work With High Volume
I have a 2000 honda civic ex and my front speakers stopped working the other day. However, if i turn up the volume super high they turn back on. They are the stock speakers and am running an aftermarket alpine head unit. Are the speakers gone? Or is it something else?
Old Aug 10, 2009 | 05:16 AM
Boxer911's Avatar
Default Re: Front Speakers Only Work With High Volume
Is there an amplifier involved somewhere? Sounds like a ohm problem.
Old Aug 10, 2009 | 06:08 AM
twentyhurtz's Avatar
sounds to me like someone adjusted the fade, and its mainly to the rear, and when you turn it up a lot you can start to hear the fronts.
Old Aug 10, 2009 | 12:43 PM
ware's Avatar
There is a 500 watt amp that powers a small 10' sub in my trunk but nothing else.
No. I fade everything to the front and they dont work unless i turn it up high. Its as if they were clogged and then when it reaches a certain point they un-clogg
Old Aug 10, 2009 | 02:02 PM
well its probably not a speaker issue if both are doing it simultaneously. Maybe the front channels inside your head unit are just taking a crap, sounds like when you turn the pot (volume ****) up to a certain point, you then saturate a transistor. maybe a resistor burned up inside the hu. you dont' have a spair unit around, even the stock one, that you can swap out real quick to see if the problem goes away do you?
i know its a pain to do those 99-00 civic radio's, but if you can use your radio keys, pull the hu out, and luckily get the factory harness to pull as far out of the cage as possible, maybe even enough to plug into the factory radio, then you won't have to pull the panels.
aantle1
Audio / Security / Video
Sep 29, 2014 06:49 AM
WalkerGSR1
22
Jul 8, 2006 04:38 PM
1.8EG-T
10
Dec 7, 2004 04:12 AM
Torridcivic
Sep 23, 2003 07:49 PM
fire7882
Jan 5, 2003 01:15 AM
