wtf?? h22a throttle body issue
Old Aug 9, 2009 | 11:58 AM
702accord's Avatar
Default wtf?? h22a throttle body issue
im doing a a h22a swap onto my 95 accord... ok
isnt the h22a body supposed to be bigger then the accords?
i matched and measured both of them and they at the same thing!!
note: my h22a came off a automatic car
Old Aug 9, 2009 | 12:05 PM
GhostAccord's Avatar
Default Re: wtf?? h22a throttle body issue
What are the measurements that you are getting when you measure the throttle plate? (inside diameter of the opening on the Intake manifold side of throttle body)
95 Accord is 58mm (ID) @ the front opening & 55mm (ID) @ the rear opening (throttle plate). The H22A should be larger than this at both ends.
Old Aug 9, 2009 | 12:10 PM
702accord's Avatar
by 5 mm? thats almost nothing.... i measured it from the front of the throttle body... the butterfly is the same as well... the back of the throttle body(intake manifold side) is probably where the difference is.
well at least i'll keep cruise control...but will it affect perfomance?
Old Aug 9, 2009 | 12:29 PM
From what is posted online the H22 is 60mm and the F22 is 58mm. Using those numbers, the only 58mm measurement I get is for the ID @ the front opening of the TB. It tapers down to 55mm @ the plate. If that is the case I would assume that the H22 would be 60mm at the front opening and possible taper as well. Take a measurement of yours from the back side if you can.
Old Aug 10, 2009 | 03:45 PM
AccorDitroN's Avatar
i dont think it will affect performance very much...not noticeable...
ItzTw
Feb 21, 2007 09:38 PM
57one
Feb 25, 2003 05:21 AM
KStuned
Jan 23, 2002 01:34 PM
