o2 sensor obd0 to obd1
Old Aug 9, 2009 | 10:33 AM
crxb16a90's Avatar
Default o2 sensor obd0 to obd1
i just converted obd0 to obd1 on my rex. running p28. i have a single o2 sensor, i was going to hook up a 4wire, but they want 80bucks on a new one. so i thinking just to run the single. i tuning my ecu with crome, and i can turn the heater off. i believe 1 wire is signal, 1 wire is power or ground?, 2 heater wire. so if i hook up the signal wire and disable the heater on ecu. i should be good right??
Old Aug 9, 2009 | 11:00 AM
blazzer's Avatar
Default Re: o2 sensor obd0 to obd1
nope i dont think you will be good you may need to disable the o2 completly
as i tried doing this same thing and it failed horribly
the 1 wire o2 in my opinion sucks so i used a 4 wire but before deciding that i wanted to not use one in general
me being preety lcuky i had hondata and my freind was using crome but he didnt have the ecu setup for anything yet. him being a nice guy he let me "borrow" his ecu, i tried using both varations to get the 1 wire and no o2 sensor and they both kinda failed i notced as well(after some 1 week testing) my fuel millage went down the hole as well.
not sure if that was my faultbased on my tuning skillz or if it just is what it is?(in a nut shell)
if anyone else has done this i would like to know as well as i was not able to get it working/functioning 100% with those diffrent variations of setup's being hondata and crome(sepretly or course) for a 1 wire and no 02 sensor
so as for now my reccomendation till some one else replies and can prive me wrong hehe is run the 4 wire 02
it may be 80$ but its not like your gonna burn it out every week, they do last quite a long time
Old Aug 9, 2009 | 12:15 PM
crxb16a90's Avatar
well, reason i don't want to spend 80 bucks, i was want to save up for a wideband. i know its off the subject, i waiting on the rom burner coming. my ecu is already chip and running some gsr map. those eprom 27c256 are reflashable right?? i read up some uv light or something. and can i use 27c512
Old Aug 9, 2009 | 12:48 PM
blazzer's Avatar
hmmm you should deffently research more on this casue honestly id say run the 4 wire spend 80$ so it will cause less problems/headaches for you i mean either way spending it will garuntee you wont have that "o2 issue" if ya get what im saying
OR just drive or not drive the car and get your wideband but ya hopefully some one knows if you can truely run with out an o2 some how im curious as well
Old Aug 9, 2009 | 01:34 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Buy a PLX setup for $230 its not that much more than $80... it will have the narrowband output that you need and then you can also have the wideband for the gauge.
Old Aug 5, 2014 | 08:15 AM
gabrielsousa's Avatar
o2 sensor ground on obd1 pinouts is D22
can i connect the o2 sensor ground on ( A23 or A26 or B2 ) ?
Old Aug 5, 2014 | 09:02 AM
4drEF's Avatar
Keyboard Humorist
Why would you even do that? just hook it up to D22 just like you know you should.
You replied to 5 threads that have been inactive for over a year and none even talk about the issue that you are working on.
Next time consider starting your own thread - just one post that directly addresses your question.
Old May 6, 2016 | 11:19 AM
is the A26 ground better than A23 ground to connect the LC1 ground ?
USDM sI
Sep 13, 2010 03:20 PM
tibss
Jan 21, 2008 09:52 AM
daidilus
Aug 31, 2004 02:22 PM
JBk24crx
Oct 2, 2003 02:26 PM
