oil pressure light flickers at idle
i have a 91 crx dx with a d16a6 multipoint motor when i got it the oil pressure light would flicker when it was at idle but when u hit the gas it would go away. so i changed the oil last night still the same just not as much. today i put a new oil pressure switch on it and the oil pressure light just stays on constant till i hit the gas and it goes away could anyone help me or tell me what to do next? thanks
just a shot in the dark, but maybe a weak oil pump that might soon be going out?
or a bad connection between the oil sender unit and plug itself.
it was at like 750 and now it sits at like 900 but since iput the new oil pressure switch on it the light stays on with out flickering when its not idleing
Check the oil pressure manually with a guage. To see exactly where its at, and not totally believe the idiot light in the dash flicking on a 20 year old car.
And determine from there how healthy it is and or if it is an electrical issue.
I seem to read super low pressures at idle on the aim data log system, although the idiot light does not come on. Someone at the track said to use thicker oil. The motor is a D16a6 in H4 trim (read mostly stock). Also in for more info....thanks....
well i put a new oil pressure switch in it and now it does it until 2000 rpms if im not touching the gas and the car has to warm up for it to come on
owneyboy
Jun 14, 2009 01:54 PM
blinger
32
May 30, 2007 05:58 AM
