Help - Replacing OEM radiator with AC
Old Aug 8, 2009 | 10:10 PM
braass91's Avatar
Default Help - Replacing OEM radiator with AC
91 Civic Hatchback DX with AC
I am replacing the OEM radiator. Does anyone have a write-up on how to replace the OEM radiator? How do you remove the lower hose from the radiator w/o removing the fan assembly? Thanks
Old Aug 8, 2009 | 10:19 PM
es.roadster's Avatar
Default Re: Help - Replacing OEM radiator with AC
don't be lazy.
you are already wasting a lot of time posting this when you could have used your 10mm to take out : radiator brackets, both the fan shrouds and grab a channel lock/pliers to squeeze the hose clamps.
OR maybe you're lazy to do so cus elk grove is HELLA hot.
i have a house down there on little harbor way
Old Aug 9, 2009 | 07:07 AM
zrickety's Avatar
take out the fan(s), drain the radiator, remove the hoses, pull it out.
install is the reverse.
it's not that hard...you can get a free service manual online that will tell you the basics. if you really need a write up, you probably shouldn't do it.
SPOON_BeIgHtEeNsEe
Sep 4, 2011 02:37 PM
AP1Shocker
Apr 29, 2007 12:07 AM
joshuma
Feb 16, 2007 03:36 PM
EuN_TeK
Mar 31, 2005 10:36 AM
deadbymorning
Sep 9, 2004 08:18 AM
