Electronic VSS WTF!??
Old Aug 8, 2009 | 08:45 PM
Clipsed's Avatar
Icon2 Electronic VSS WTF!??
OK... So I have been trying to figure out this VSS situation for the LONGEST time. I found this while searching...
http://hondaswap.com/general-tech-ma...es-vss-128865/
Now, according to that, they are the same except for the gears... BUT that is obd2... I believe that the sensors I have are obd1. Also according to that, the d series is a plastic gear, and b is a metal gear. On the ones I have I dunno what they came from, I think my plastic one is from a D, dunno about the metal one... BUT The metal on there are 2 mounting holes which neither of them line up with the hole on my tranny to bolt it down.
On the other hand, the d series one DOES line up... I'm confused now... They both have the same size gear, and also have the same number (20) teeth. Should I do the metal gear swap over to the plastic gear holder? I dunno what I should do OR if it will even work.
Thanks for any help.
EDIT-
After closer inspection, as similar as they look, they ARE different and the gears pins are NOT swappable...
Old Aug 8, 2009 | 08:50 PM
Clipsed's Avatar
Default Re: Electronic VSS WTF!??
Edited the first post...
Old Aug 8, 2009 | 08:52 PM
DCRB's Avatar
do they have any part numbers? if they do look them up to varifie which one is which. then yes put the metal gear on the part you are going to use
Old Aug 8, 2009 | 09:41 PM
es.roadster's Avatar
if you're trying to make your integra cluster work properly,
use ANY of the electronic vss that you can get a hold of.
wires go like this, ( snap face, facing you ) power / signal / ground.
if it would bolt in perfectly, it's fine. just as long as the vss gear is IN the tranny.
Old Aug 9, 2009 | 12:27 AM
FOMULA91's Avatar
The left VSS is from the Automatic D & B-series and the right one is the D-series 5-speed VSS.
Old Aug 9, 2009 | 10:30 AM
Clipsed's Avatar
thanks for that info, so it is for an automatic d AND automatic b series, thus why it has two mounting holes?
TOM KREUTZBERG
Feb 13, 2014 04:04 PM
RacerStev
May 14, 2013 05:24 AM
bnmm
Transmission & Drivetrain
Apr 28, 2012 12:28 AM
2 0 3
Jul 30, 2007 01:02 PM
zCivic
Dec 10, 2006 10:45 AM
