Goofy idle issue
Old Aug 8, 2009 | 06:34 PM
s_vares's Avatar
Default Goofy idle issue
I have a 2002 RSX Base, Everything is stock.
It seems to have some low rpm drivability issues I need some help with.
When driveing and clutch is pushed in the idle falls to about 800RPM istantly, then comes back to about 1500 somtimes 2000 for a few moments then slowly falls. Sometimes it will bounce up and down 1K RPM a little bit. Idle is in the right spot at around 800RPM There are no vaccum leaks that I can tell.
I removed the throttle body, cleaned the IAC, No check engine light, have reset the ECU, Checked throttle cable tension. Im at a loss! Help guys
Old Aug 8, 2009 | 08:58 PM
crazzyvtec's Avatar
Default Re: Goofy idle issue
Bumpp
Old Aug 8, 2009 | 10:15 PM
dem_'s Avatar
seems like you are running super duper lean.
make sure that your ecu is set to stock. Are you 100% positive thaat nothing is modded? your ecu might be sending a message to your engine that makes your engine have the wrong air-fuel mixture. double check that your engine is stock (only thing i can think of is maybe a different degree cam? dunno, not thinking clearly =P), if it is stock, reset the ecu again and make sure it is the stock map.
Things should get cleared up by then. good luck with it.
Old Aug 9, 2009 | 03:22 AM
hawaiiancb74's Avatar
bleed coolant?
Old Aug 9, 2009 | 06:22 AM
s_vares's Avatar
I did not bleed coolant, my car is 100% stock with no check engine lights, very well maintained. I will try bleeding coolant
Old Aug 10, 2009 | 02:14 PM
s_vares's Avatar
I found out its a bad IAC valve.
Anyone got a working one they would like to sell??
GoldieWang
19
Dec 8, 2015 01:03 PM
Elitesky
Jul 10, 2010 01:23 PM
NA_B_FTW
Feb 11, 2009 12:06 PM
ITR EG
Apr 12, 2008 09:29 PM
cdx280
Sep 1, 2005 08:45 PM
