boosted b16a ef no start
this is my first help thread on honda-tech so let me know if you need more info.
so i just finished my rebuild.
i dropped the motor back in, hooked everything back up.
the car cranks but does not start.
i have spark and fuel.
the spark plugs are sparking, and fuel is getting into the cylinders.
the compression cold(obviously) was 100-100-100-100.
the car was running before the rebuild.
i have checked and re checked and triple checked that everything was hooked up properly.
i just dont know what else to try.
i have a 1991 honda civic si.
it has a boosted b16a in it.
any and all help is greatly appreciated.
thanks, scott.
thanks, scott.
also the compression before the rebuild was 150-150-35-150
rings went bad in that cylinder. the top ring cracked.
