Where do I look to see if i'm OBD1 or OBD2?
Old Aug 24, 2002 | 10:55 PM
MR. ARIZONA's Avatar
Default Where do I look to see if i'm OBD1 or OBD2?
UH...........Sorry if this is a stupid question but where can i find this at? I have a 94 INTEGRA LS and I got a b18b swaped in. I don't know what year it is, all i know is that it's a 96+ because of the diffrent valve cover. I really wanna find out. Let me know...thanks
Old Aug 24, 2002 | 11:23 PM
PaChiLa Leader's Avatar
Default Re: Where do I look to see if i'm OBD1 or OBD2? (QUICKTEG)
check the plugs
00+ should be ABC connector
96~99 should be ACD
as you can see from the pic
OBD IIb (left 3 plugs used)
OBD II ECU
OBD I ECU
OBD 0 (JDM PR3 and PWO)
Old Aug 24, 2002 | 11:28 PM
Default Re: Where do I look to see if i'm OBD1 or OBD2? (PaChiLa Leader)
And where in the hell do i find those in the engine compartment? LOL
Old Aug 24, 2002 | 11:49 PM
Westrock2000's Avatar
those are ecu's located behind your passenger kick panel, also the vin on the block can tell you what year, If I got time i'll get out the helms later and give you the legend for figuring out the VIN
Old Aug 25, 2002 | 12:00 AM
Default Re: Where do I look to see if i'm OBD1 or OBD2? (Westrock2000)
Do you know where the vin is on the block? Where do I look? Under the car? Probably be better if you just showed me were the ECU is so i can check which OBD i have........
Old Aug 25, 2002 | 12:44 AM
ahead's Avatar
the ecu is on the passenger side footwell inside the car. its on the right side behind the kick panel. goodluck
Old Aug 25, 2002 | 12:50 AM
Default Re: Where do I look to see if i'm OBD1 or OBD2? (ahead)
Anyone else?
Old Aug 25, 2002 | 01:19 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Anyone else?
what are you asking for?
the VIN plate is on the front of the block for 96+ i believe.
they already explained to you where the ECU was.
on a side note if you have an RSM i'd assume you'd seen the ECU at least once...
[Modified by dLo GSR, 2:19 AM 8/25/2002]
Old Aug 26, 2002 | 12:27 AM
Default Re: Where do I look to see if i'm OBD1 or OBD2? (dLo GSR)
LOOK CLOSER at that AVATAR OF THE RSM.....do you honestly think that car is mine?
Old Aug 26, 2002 | 01:50 AM
*shrug* beats me, i can't tell what kind of car that is. it's a friggin 70 x 70 icon.
Old Aug 26, 2002 | 02:06 AM
ragejed's Avatar
looks like a RHD in the avatar...
[Modified by ragejed, 11:07 AM 8/26/2002]
Old Aug 26, 2002 | 02:12 AM
B2FiNiTY's Avatar
How can I tell?
What car do you have?
Old Aug 26, 2002 | 04:18 AM
backlash's Avatar
Default Re: Where do I look to see if i'm OBD1 or OBD2? ([B2]FiNiTY)
He has a 94 LS with a swapped B18b
Old Aug 26, 2002 | 01:08 PM
Yea, but it's Right Hand Drive...
Old Aug 26, 2002 | 01:09 PM
Default Re: Where do I look to see if i'm OBD1 or OBD2? (backlash)
WOW, how the hell did you know that? SNEakY ***! lol
Old Aug 26, 2002 | 11:32 PM
why swap the same engine in (unless it got blown)?
and i'm not a detail-specific enough kind of person to notice that its' RHD.
Old Aug 26, 2002 | 11:58 PM
When i bought my car it came with NO HEAD. The block was exposed to sun for over a year and i would of had to rebuild. Cheaper to swap one in instead. B18b all the way!!!
Old Aug 27, 2002 | 12:01 AM
Also, i removed the kick panel. (they didn't even screw it back in when they did swap) it came right off. I still can't tell which ECU i have. ALL i saw was L H on the side of it in BIG LETTERS and a bar code of some sort. Would i have to unscrew it off the car and move it around? Would i **** up anything if i unscrew it to see?
Old Aug 27, 2002 | 12:50 AM
unscrew it, pullit out, and look at the connections, and compare to the pics.
it's just a computer. it'll be ok if you pull it out
Old Aug 27, 2002 | 01:01 AM
Well alrightythen I will! I'll let you guy's know tomorrow, not like you care....
Old Aug 29, 2002 | 05:01 PM
dc2dragster's Avatar
From: eastside of the beach, westside of the coast, Long Beach, CA, usa
check the front of the head it has little circles just above the header it has the year on it two digit
Old Aug 29, 2002 | 10:58 PM
Default Re: Where do I look to see if i'm OBD1 or OBD2? (dc2dragster)
Hmm, i'll have to look , thanks man
Old Aug 29, 2002 | 11:06 PM
BTW 96+ is OBD2
Old Aug 30, 2002 | 12:27 AM
Thanks
jake12ryder
11
Feb 15, 2014 06:43 AM
Boostn B20
Jul 29, 2008 12:00 PM
LpBoy2004
Feb 13, 2004 08:25 PM
aonick
Apr 29, 2002 05:20 PM
