Need help passing inspection in Va
Old Aug 8, 2009 | 10:56 AM
solo227's Avatar
Default Need help passing inspection in Va
I got a 1996 EJ* with a B18c swap... The guy at the inspection place said he couldnt get any connectivity with the scanner... How do I fix this problem?? Im running a ODB2 P72
Old Aug 8, 2009 | 11:06 AM
masuya_04's Avatar
Default Re: Need help passing inspection in Va
from what i've heard, it's harder to pass a b18c with an obdII then it is with an obdI. my suggestion is, search to see if people have had better luck with an obdI to pass inspection. lately H-T has had a lot of threads about passing inspections, and why they did and not passing inspections, and why they failed.
hope this helped you.
good luck!
Old Aug 8, 2009 | 11:55 AM
instrument's Avatar
go to a rural location in va that doesn't check..there's tons of em.
Old Aug 8, 2009 | 12:59 PM
40mpg_dx00's Avatar
Are you still in contact with whoever did the swap? Your DLC might just be there for show if they got lazy and didn't install it properly.
Old Aug 9, 2009 | 04:37 PM
solo227's Avatar
Yea I can still get in touch with him... Whats a DLC?
Old Aug 9, 2009 | 06:53 PM
rehaf's Avatar
DLC stands for the data link connector under the dash where OBD2 scanners connect.
Check to see if you have battery voltage on pin #16 of the DLC with the ignition switch in RUN. Some scanners will not communicate without power on this pin. Could just be a blown fuse.
Old Aug 10, 2009 | 04:13 AM
solo227's Avatar
thanks alot
pliskin8
Apr 9, 2008 04:06 PM
Wes V
23
Aug 13, 2004 04:41 PM
Galaxy Si
Jul 30, 2004 03:38 PM
nfiedler3
Dec 17, 2001 12:59 PM
